A few other things I’ve noted about the new Golf 7 GTI:
The Golf 7 GTI is easier to place to the roadway than the previous model MKV and MK6 Golf GTI’s. The MKV was the worst to place on the roadway, with heaps of factory induced understeer & body roll. The MK6 with XDS and stiffer rear sway bar was greatly improved for driver ease of placement. The MK6 with DCC is much better again in terms of placing the GTI exactly where you want it. The Golf 7 GTI is so much easier to place than all preceding GTi models.
Traversing around the mountainous roadways over the past few days, I have not struck one cats-eye on my side of the roadway, as the Golf 7 GTI offers greater directness and sharpness when placing it on the roadway around corners, I guess this can be attributed to the progressive steering, lighter weight, longer chassis footprint, less under-steer and more proactive XDS system. It’s not all good though.
I’ve gleaned that the XDS system in the Golf 7 GTI is also more proactive than the previous model GTI in damp conditions, with moist & damp to wet roadways. It’s not a stability ESC type of engagement, but a proactive dab of the front and sometimes rear brakes to aid the Golf 7 GTI into corners. I’m forming the opinion that due to the extra focus in the 7 chassis, in concert with lighter weight & greater mechanical & effective tyre grip, everything happens quite a bit faster in the Golf 7 GTI in comparison to previous models.
I think Volkswagen have taken that into consideration when developing the XDS/ESC functions on the Golf 7 GTI. Be mindful that the proactive XDS/ESC nudges do occur on entry into bends, which I cannot see changing in the other variants such as the PP GTI and Golf 7 R. This does take a bit away from the driver’s ability to muscle the Golf around a series of bends. If you want the ultimate in driver involvement, look elsewhere. Thankfully, the Golf 7 GTI makes up for the loss in ultimate driver engagement in added refinement imo.
The higher geared manual transmission Golf 7 GTI on the highway on a slight to moderate incline at about 100kph will struggle to increase speed on light throttle application in 6th gear. The port injection may also have something to do with this in addition to the long final 6th gear ratio of the manual transmission Golf 7 GTI. I’d agree with some media reports that the DSG version of the Golf 7 GTI would do a better job of masking this, in addition to being slightly lower geared for the top 6th gear ratio.
In damp to wet conditions, I’ve found that Sport setting is more fun going uphill during mountain climbs as the Sport setting encourages the driver to be a bit more ham-fisted. Normal setting for coming down the mountain-side in damp to wet conditions, allowing for that bit more chassis movement & articulation adding driver awareness and feel, in addition to slightly more natural steering, feel for lower-grip situations. In the dry, Sport setting is the one to go for to carve up and down the hilly terrain.
The manual transmission Golf 7 GTI is more involving than the DSG. This requires more focus from the driver, which in turn keeps the driver from letting the GTI get away from you in terms to sticking at or below the speed limit, especially on downhill runs. Going uphill, you do lose 5-10kph during gear-changes in the manual, which aids the driver to keep an eye on the speedometer.
Finally:
I’m going to ask you guys to do the arithmetic when vying for that empty gap in traffic. Golf 7 GTI Manual Transmission with 350Nm at a lowly1500rpm weighing in at 1213kgs (maybe 1-2 kilos more with window tint) … or … Ray’s almost fully optioned MK6 Golf R DSG with 330Nm at a higher 2200rpm weighing in at around 1500kgs?
Which vehicle is most likely to secure that empty traffic spot?
WJ
