Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: MK 7.5 Golf Traffic enablement
    Nov 2010
    Calamvale Qld
    Quote Originally Posted by rosslm View Post
    I can confirm the above setting does activate Traffic Information
    Attachment 31563
    Hi Rossim,
    What biuld is yours as mine is MY18 Built 10/17.
    I have followed the above but either OBD11 and VCDS will not allow me to code the BYTE 13 RDS NOT DEACTIVATED. Mine is deactivated, but RDS TEXT PLus is activated!!
    Anyone with any ideas??
    Candy White 3T Superb Elegance Combi 2.0 TDI DSG Paddles shift's, Elecy Taigate, Towbar, 9W7 bluetooth, t20 tints, matts and flaps
    Business Grey NP 140TDI Superb Combi with Tech & Comfort Packs, towbar and rubber matts
    Jul 2009
    QLD
    Quote Originally Posted by dec76 View Post
    Hi Rossim,
    dec76
    Mine was built 06/17 my OBD11 allowed me to edit BYTE 13 RDS and Radio_Text_Plus did you set 1024 first also is RDS on in your MDF setup?
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
    Nov 2010
    Calamvale Qld
    dec76
    Hi Rossim,
    I have followed all the ways to do it!! RDS enabled and TP enabled in Discover H/U. OBD11 wont change the BYTE 13 RDS and Radio_text_plus saying not allowed!!!
    have done quite a few of these MQB cars and this has me stumper!!
    Are you in Brisbane? if so maybe we can catch up and compare notes
    Thanks in advance
    Heath
    Jul 2009
    QLD
    Hi Rossim,
    Thanks in advance
    Heath
    Heath I'm on the Suncoast might be easier to find someone in Brisbane also a VCDS may be an option, my car is a Golf R Wolfsburg there may be a difference with the Skoda unit.
    Jun 2016
    Did today on a Co-workers Golf 1.4T Mk7.5 via OBDeleven
    Set Fee based Traffic to: 1024
    byte_13_RDS to Not_Deactivated ( ie Activated)
    byte_13_Radio_Text_Plus was already 'Activated'
    Backed out of Coding to home screen, Press and hold power till it turns back on. Select Traffic after the reset, worked in like 30sec.
    Thanks!
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
    Mar 2009
    Unfortunately lost my Traffic functionality after needing a new controller module to get App Connect & Nav to work again.
    Not sure I'll bother getting it added again as I use my phone GPS more than VW's... although having a cable to do it myself would be handy..
    Jul 2018
    ^^^^ here's the VCDS screen equivalent (using the "yellow" long coding helper screen from the latest SW version)
    So, set Byte 13, Bit0 & Bit3
    I'm going to check this next time I have access to a cable. I'm having issues with my 2016 Comfortline not enabling the TMC as well
    Jul 2018
    I managed to check this last night and I don't have all those bits available. I did copy the binary (changing 1000 to 1001) I'll see how I go with TMC next time.i go for a decent drive. After a hard reset it is still showing -TMC- in the traffic menu.
    Aug 2018
    melbourne
    is that works?
