Results 1 to 5 of 5
Thread: Mechatronic Gasket Leak
    Jan 2018
    Hi guys, so took my mk7 tsi to get serviced at a new place and they said that my mechatronic pan gasket is leaking. They gave me a quote to replace the pan gasket for $700. Wondering if this is necessary to fix or a big issue? If it is 3 hours labour a fair amount to be paying.
    Thanks
    Mornington Peninsula, VIC
    I guess it depends if it's leaking or just seeping, low fluid on a DSG can cause false neutrals; and that can be unsafe.
    The sump pan, gasket and fluid should be all done at the same time.
    being a TSI, i guess you have the 7 speed yer?
    if so there is a kit to do this job, VAICO V10-3545-XXL includes all three parts and can be found for about $ 100 USD online.
    3 hours is normally the time quoted for a mechatronics replacement, so that time is a bit high.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jan 2018
    Yeah it's the 7 speed dry clutch dq200. Is there any way to check the fluid levels on the dsg or are there normally any warnings when it gets low? Not too sure if it's leaking a bit or just seeping.
    I think the mechanic took a picture so I can just tell by looking at how much fluid there is to see if it's leaking or seeping?
    So the fix includes new gearbox oil as well. Just weary as first time at this mechanic and they're not cheap so not sure if they're exaggerating the issue to get me to fix it.
    Gear oil on the 7 speed is just that, 75w90
    Mechatronics holds almost a full litre of hydraulic oil, if you buy VW stuff, its the same as you put in the roof system on a mk1 Golf cabriolet. It would need to be significantly down to. Like 25% I reckon before you would notice anything. A few teaspoons wouldnt make a difference, although it would spread out over a large area.
    Jun 2018
    Unfortunately there is no simple way to check the mecha oil level. How many KMs your TSi has it? If around 40-50k km it's advised to change the oil, even VW saying that is a lifetime one. It will improve the longevity of the mecha and help to prevent failures.
    I would check another prices around just in case. I used to do mine every 40K km.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap, 110TSI Turbo upgrade with Stage 2, Bilstein B12, Pretoria 19", GTI PP Sway bars upgrade F/R, Full GTI Tartan interior, GTI colour Cluster, R's Bi-Xenon with AFS retrofit, GTI brake upgrade.
    More to come...
