Hi I have taken the towbar off my mark seven without realising that the bolts are specifically torqued . I have a Hayman Reese towbar. Wondering if anyone knows what setting I should be using to retension the bolts. By the way the towbar is on the older type with bolt mated to two flat metal bars
Just checked with Heymann Reese and they’ve confirmed it should be tightened to 190 Nm
190nm is the equivalent of hanging 190kg off the end of a 1m long lever - so yeah very very tight.
