Map version is 90 as in the file name if for Discover Pro You need to state what MMI you have a s the Media version is different as per replies on prev page
Does anyone else have issues with the SD card not being read? Am using the same 64gb card as used in the past with no issue. Also would like to know what the actual version number is for this update.
Wolfsburg 7.5R. Lapiz Blue hatch DSG with sunroof.
What you have is defined by the model of car you put in then the year of it and it should come up with a choice of units. As I have the Pro 2 I forgot there was an older one but it doesnt show when I put my vehicle in.
Both units would take the same map and you can check by going to the version information page in your unit and it will give the map details
I down loaded the file, do I then unzip it and extract the specific files I need to an SD card or do I load all the unzipped file in its entirety onto a SD card and then update.
One less chance of error is the probable reason. why make an extra step when you dont need to.
You can do it however you like provided the result comes out the same but for some reason I have found it doesnt always. Also takes longer to unzip to drive 40 mins and then copy to card, maybe another 20mins when it will unzipo to the card in one go
Extracting to the HDD only took about three minutes tops but I have yet to copy it to a card. The method I use to avoid any problems is to use control/A and that selects all the files to copy and can't leave any behind. I don't think much of VW's nav system and never have even in my previous car but I thought seeing as the car is four years old I had better update it anyway.
