Thanks for the link and the installation information works great.
2020 Golf R Wagon.
I have downloaded the VW DiscoverCare app for MacOS. I am keen to update the maps for my car. Sadly, I just discovered that my plastic folder in my glove box is empty - no SD cardNor in either of the slots as I checked. I bought my VW Golf last year and did not think to ensure the SD card was there, amongst all the other things of concern when buying a car. I assume I still have the 2013 maps installed. Is there a way to make any old SD card work or am I required to get hold of a genuine VW one? Without buying a new one, I assume this could be possible as many Golfs between 2013 and now have been wrecked for one reason or another. Can I make use of any SD Card, as the app asks me to insert my genuine precision-made German VW SD card to continue the process... Thanks for any advice.
2013 Volkswagen Golf 103TSI Highline 7 Auto owner.
Do you have the Discover Pro system, noting your signature of a Highline and are you running maps without the SD card now? If so you have the maps on the vehicle's hard drive. Pre 2015 cars (without Carplay or Android auto) required a software fix before allowing map updates but that was the basic Discover version so unsure with the Pro version.
You could try the link on post 165 with any SD card up to 32 gb, but try and work with non apple products.
If you only have the Discover version which needs the SD card than yes you can use an authorised VW one (part number 3GO919866) only. Can be 2nd hand. If your maps are original 2013 than you may need to ask your dealer with what they could do, as highly unlikely the map fix has been applied.
Flipper Dog
Now - T-Roc R, Audi Q5
I think I will just stick with Google Maps on my iPhone and leave the car the way it is, too hard to figure it outThanks anyway.
Here is the map for MIB2 units. Its from November last year. So its only one version out of date I downloaded it for a friends car but havent seen him since then so it might help someone Its 4.3GB File name is Discover Media2_MRM3_1420_V12.7z
https://drive.google.com/file/d/15sY...ew?usp=sharing
Also prev version form June 2019 Discover Media2_ MRM3_1310_V11.7z
https://drive.google.com/file/d/1AnT...ew?usp=sharing
Mk 7.5 GTI | Manual | Indium Grey | Driver Assist | Infotainment | Luxury Package
