Page 29 of 33 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 326
Thread: Maps update
  1. #281
    Mar 2009
    Melb
    Yup, wait as in 1 hour for it to digest hahaha
    Tig 162 R-Line; Audi TT
  2. #282
    Aug 2008
    Installed v. 97 to our DiscoverPro. Just put the SD card into the car's slot, initaited the transfer , it got to 2%. Turned off the ignition, we drove the car for a day or two and it is done, in the background. No need to worry about battery chargers etc.
    MY19 Tiguan Highline R-Line
  3. #283
    Jun 2021
    Melbourne Vic
    Quote Originally Posted by ConfusedGolf View Post
    No update for Discover media
    Anyone seen anything of the Discover media update yet?
  4. #284
    Pacific Paradise QLD
    Quote Originally Posted by Third Golf View Post
    Volkswagen Map Updates Been there for over two months
  5. #285
    Jun 2021
    Melbourne Vic
    Thanks Hillbilly,
    Apologies for slow reply; more pressing matters than Map Updates got in the way!
    I did attempt to update back in early July. I've successfully used the DiscoverCare Ap the last two updates, as I have the VW supplied 8Gb SD card.
    I tried several times to run the update then, but it kept stalling on the initial Backup at around 30% complete. I gave up thinking maybe a server issue or incompatibility. Hence my recent enquiry.
    On checking my previous installation notes, I discovered that last time I had previously cleared the saved Backup folder prior to running the DiscoverCare Ap.
    Once I'd done this, all went smoothly. Whole process taking about an hour on the computer. Card recognized in under 20 secs back in the car, and could immediately confirm that the new 2022 map version had been installed.
    Thanks again for your earlier prompt.
  6. #286
    Thanks Hillbilly,
    Discover care is no longer used as ver 1.04 was rubbish it was not on the page for some time but I see for Media its back. Oh Well
    Just download to a HDD and unzip it to an SD card
    I had Discover Care and havent been able to get it to run properly for 2 years so just do as above
  7. #287
    Jun 2021
    Melbourne Vic
    I had Discover Care and havent been able to get it to run properly for 2 years so just to as above
    Looks like I might have fluked the update this time.
    I've screen-snapped your response and filed it with my DiscoverCare stuff, should I encounter problems next time.
    Much appreciated!
  8. #288
    Sep 2021
    Perth WA
    Hi
    I have just got a 2019 Amaroc. It has a Discover Media system with 2 SD slots on the front. It came from Sydney and is now in Perth. It came with out its Navigation SD card ………
    I’ve followed VW’s DiscoverCare navigation update instructions to put the latest maps on an new SD card. It didn’t work. I’ve read this very informative thread and other forums to try and get my system to work. But no luck. So I’m wondering if anyone can help.
    Here’s an overview of what I’ve done.
    I have downloaded the latest maps - World bundle 3 - Updated: 2021/06/21 to a new formatted SD card
    The download folder on my windows PC is titled DiscoverCare_v.1.0.4_win
    The title of the maps according to the DiscoverCare app is shown as 5NA.919.866.BN 1710 MRM3 2022
    When I open the SD card the following single folder is shown
    maps
    inside this maps folder are the following folders (don’t know which number is the Australian maps)
    22
    23
    26
    27
    EEC
    When I insert the SD card into my system I get
    Navigation database not available
    I have done a reboot to my system by holding the left hand on/off knob for 5 seconds +, both with card in and with the card out.
    I still get the same. Navigation database not available
    So by holding down the MENU button, I've got some system information which I thought might help. The screen shows the following
    Installed SW version MST2_EU_VW_PQ_P0475T
    Installed SWMU version 0475
    Software version H29.319.76_STD2NavPQ_EU
    Current version MST2-EU_VW_PQ_PO475T (0475-1)
    When I now try to update using the update button and selecting the SD card option. The following error message comes up
    Unable to read the Release Information file.
    No release available.
    Can’t find update container.
    On another forum its suggested that a genuine VW SD card is required that has some CID encrypted coded (unaffected by reformatting) that is required for the system to read it - the DiscoverCare manual doesn't say anything about this, and its not been mentioned on this forum. So any suggestions on what to try next, or have I missed something in the thread? Thanks in anticipation.
  9. #289
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by RocMan View Post
    That's correct about the genuine Volkswagen SD card.
    The process you have done is correct but without the card encryption on the SD card the Discover media will not allow the card to be read.
    You need to look for part number 3G0 919 866 (followed by a letter or two), does not matter what mapping information is on the card as you will over write it with what you have done.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  10. #290
    Sep 2021
    Perth WA
    Thanks Flipper, according to my local dealer who has at last replied, the part number for the latest Australian map data SD card is now 5NA919866AM Seems the number changes with each new version of the maps. Price a hefty A$235.
    I think I have seen in some forums that you can even use a European maps SD card, as its only the CID code that is important. You then over write the SD card with your countries maps - Australia in my case. Is this correct? Also does anyone know which of the files on the download on my PC
    22
    23
    26
    27
    EEC
    is the Australian map.
