Page 20 of 33 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 326
Thread: Maps update
  1. #191
    Pacific Paradise QLD
    Quote Originally Posted by FastMitch View Post
    Downloaded ok (very large file). Will let you know when I apply the update on the tiggy.
    How does the version numbering work ? What does the P88 stand for ?
    The answer is in reply 186
  2. #192
    Apr 2018
    I had read #186 but wanted to understand the P88 nomenclature. Is it just an incremental (i.e. next version is P89 or Q89) ?
    Does the P88 correspond to a Year / Quarter version in any way ?
    Looking at the extracted DIR, the file timestamps are for the Aus Map Files under Mib1 / NavDB are dated 12/2019
    Looks like the package was generated 01/2020
    I may have mis-read this thread wrong as I understood P88 was a 06/2020 Map update release but this is not reflected in the file time-stamps
  3. #193
    Yes
    sequential
    I dont know nor worry about that
    Look at your screen it was 85
    You worry too much, be thankful they are still free
    If you have a PRO it uses whichever file it needs depending on the model I guess
  4. #194
    Apr 2018
    Can I use a USB stick to load the files or does it have to be an SD Card ?
  5. #195
    I think so why dont you try it and tell us
  6. #196
    Jan 2020
    Quote Originally Posted by Rooboy View Post
    getting checksum error yesterday. 40gb free harddisk space and 32gb sd card formatted as Fat32.
    Yeah - same happens with plenty of free hdd space and a 64gb sd card. Suspect their software is comparing two different files - hence also why they've taken down the discovercare downloadable exe. Would have thought this would be pretty simple code they're maintaining.
    But anyway, as Hillbilly says, go the direct link for the downloadable.
  7. #197
    Have got it downloading through Discover Care 1.04 now will update later with results
    You have to format cards in FAT 32 not an easy thing to do without a 3rd party software for a 64GB card
    WINDOZE wont do it 5PM DOWNLOADED AND GOT A CHECKSUM ERROR
    First time ever and have previously downloaded earlier maps with same program without troubles so weird
    Redid it with Discover Care and got the checksum error again so best just use the direct link I think
    Direct downloaded from the portal and Win RAR says the file is corrupt so I give up
  8. #198
    Bump............................
  9. #199
    Use 7zip to unrar the file. Winrar has been dodgy of late extracting certain files. 7zip is much better.
    Sent from my SM-N975F using Tapatalk
  10. #200
    Quote Originally Posted by onefinger View Post
    Been using it forever and NEVER had any trouble Its not the unzipper its Discover Care or the map file that has the problem as it unzips the Skoda version perfectly and its the same map with a different file name
