No looks like mine is the 0062 version. Not sure how I get the new one
is your software on a pc or Mac?
Printable View
I used a notebook with Win10 point the download to a local directory once finished [2hrs] the program automatically updates a blank SDRam 32GB [30min] then with the ignition on place the SDRam in one of the SD slots in the glove box the Discover Pro will detect the upgrade follow prompts to upgrade [30min] turn off fan, interior lights, headlights etc. front leds will stay on. Note the current Discover Pro stores the files internally.
Just a quick side note, I left my ignition off and simply turned the Head Unit on. Still worked.
Ok just doing this now. Should I be worried that my SD card has under 8GB of usable space when the update (I think) is over 8GB??
Currently downloading files, but the backup is over 8GB....
Edit... Files saved to SD card no worries. But MIB II didn't recognise the files....off to VW I go...
Hey guys, in the app which option did you choose for "Market":
Multi Region Map2 for Media Gen2
Multi Region Map
Multi Region Map1 for Media Gen2
Not sure which one i need?
Never mind, figured it out. Has to be Multi Region Map and then in the next step you select the head unit and then it picks it up :)
Set it to multiregion, then select your car, then discover pro 2, it should show up as update available.
As KennyC posted above.
I kicked off the update on my way to work. It was updating as I was driving :)
I am now at work and it's at 56% so I have to now wait in car until it's finished.
