Is it better to get the Skoda version or the VW version direct from the VW website ?
https://vw-maps-cdn.lighthouselabs.e...IBH3_ROW_NT.7z
Works without Discover Care as well Is ver 88
If you have Discover Care on your computer it will find the new map .Have just started the download
Any of the links above will give you the map It is the same thing on each site but has a slightly different name . Thats all so take your pick
I had no problems running it through DiscoverCare last year but getting checksum error yesterday. 40gb free harddisk space and 32gb sd card formatted as Fat32. The log was showing the following.
2020-07-11T11:47:44 [Info][General] Delete backup: C:/Users/pc-use/DiscoverCare/Backups/{2e67d797-8fbe-42de-a875-5b828c942ab9}.mapbackup
2020-07-11T11:49:42 [Info][Download Manager] Set UI NOT_STARTED
2020-07-11T11:49:47 [Info][Download Manager] Start Download_SL
2020-07-11T11:49:47 [Info][Download Manager] Set UI RUNNING_DOWNLOAD
2020-07-11T14:33:25 [Info][Download Manager] Download finished: SUCCESS
2020-07-11T14:33:25 [Info][Download Manager] Set UI RUNNING_MERGE
2020-07-11T14:46:32 [Info][Download Manager] Merge was successful
2020-07-11T14:46:32 [Info][Download Manager] Set UI RUNNING_CHECKSUM
2020-07-11T14:48:05 [Info][General] R:e05d668f4a1a3bc8fd8a1884637dddc2
2020-07-11T14:48:05 [Info][General] C:9d3e11692ecbbb50dc89e8bd4ea7e3d3
2020-07-11T14:48:05 [Info][Download Manager] Vorberrechnete Prüfsumme -> e05d668f4a1a3bc8fd8a1884637dddc2
2020-07-11T14:48:05 [Info][Download Manager] Prüfsumme Berrechnung -> 9d3e11692ecbbb50dc89e8bd4ea7e3d3
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
Discover care used to be on the Portal but seems to have problems ATM so those of us who have used it before, downloaded it and run it from the PC as would be normal I would think
A lot of fluffing around about all of this Just use the direct links to the actual file and do as I said in my last reply. I rarely bother using it as its often faster the other way
You posted the link yourself so what happens when you use it.
Downloaded ok (very large file). Will let you know when I apply the update on the tiggy.
How does the version numbering work ? What does the P88 stand for ?
