Page 50 of 51 FirstFirst ... 4048495051 LastLast
Results 491 to 500 of 507
Thread: Maps and POIs for Discover Media
  1. #491
    Jan 2013
    Here is my file including all the cameras in Australia (fixed, red light, point to point, mobile, etc) altogether 1912 map points. Created by POInspector software and POIs downloaded from poidb.com. Also added the POIs for Mcdonalds.
    If you are struggling to import POIs to your Discover Media unit, try this. Download the zip file, unzip it and copy the PersonalPOI directory and the metainfo2.txt file onto your SD card then import it.
    Uploadfiles.io - POI.zip
    Last edited by PeteC; 21-07-2018 at 07:35 PM. Reason: Updated the link with new files
  2. #492
    Dec 2015
    NSW
    Quote Originally Posted by PeteC View Post
    Thanks for the file, BUT I'm unsure of the benefit of having any mobile cameras included. What am I misunderstanding ?
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
  3. #493
    Jan 2013
    Hobart Tasmania
    Good work, thanks for sharing, I'll play around with POInspector when I get a chance, but the import file worked fine on my 2018 Golf Comfortline with 0821 MRM2 2017/18.
    My16 Golf Alltrack, DAP
    MY18 Golf Comfortline
  4. #494
    Jan 2013
    Quote Originally Posted by bgroper View Post
    I had the same question when I saw the name, but then I read the description on poidb.com:
    Mobile speed cameras are now being used in several states to reduce speeding on the roads. These cameras are set up in different locations that vary each day. This group of POIs gives locations where they are most frequently set up.
    So at the end I decided that I want to know the frequent locations for mobile speed cameras. I know two locations nearby where I live, where the police stops couple of times per month. Better safe than sorry and it is only a couple of spots, 23 I think for whole NSW where I don't mind having an extra beep and an icon on the map.
  5. #495
    Jul 2018
    Dee Why, NSW
    Need Help Please
    Hi All,
    I have been following this thread closely, however hoping someone can help. ive got a mk 7 Wolfsburg Hatch and it seems i am running the latest maps. I had this done while having some work done on replacing my mirrors at the same time.
    My System Information is showing:
    Device Part Number: 3Q0035846
    Hardware: 820
    Software: 0627
    Nav Database: 5NA919866C
    1010
    MRM2 2018/19
    The problem i now face though is i seem to have lost my traffic reports, which i enabled using OBD Eleven. When presing the traffic report button on the head unit "TMC" is now crossed out. Since having the new map update i checked to make sure the Traffic Report settings were correct in both OBDEleven and on the Discover Media Nav unit and am stumped as to why the reports arent showing anymore. I have read in a previous thread that the Map update P68 works fine with Traffic Reports. I have even downloaded the P68 map udpate (approx 24GB) however my understanding is map updates for my unit can only be done via the supplied SD card from factory, which only holds 8GB of data.
    Hoping someone can please help with my dilemma. Would love to have TMC working again and unfortunately i dont have a backup of my previous maps stored anywhere. Cheers
  6. #496
    Dec 2017
    Quote Originally Posted by JoshWolfsburg View Post
    Hi All,
    Hardware: 820
    Software: 0627
    1010
    MRM2 2018/19
    I went back to previous version of map to get my TMC working again as TMC did not work for me either with MRM2 2018/19.
    http://vw.download.navigation.com/au...-1245.xROW2.7z
    Choice is yours though.
  7. #497
    Jul 2018
    Dee Why, NSW
    Quote Originally Posted by ArdiL View Post
    Thanks ArdiL. Will download the previous map from the link above and see whether TMC works again.
  8. #498
    Jul 2018
    Dee Why, NSW
    Yep as you had said, reverting back to the 0821 map revision brought back TMC. I have also read that the Map update from December 2017 also is working with TMC. I believe its the update before the latest P71 release.
    Has anyone got a link or a back up for the ROW P68 maps (released December 2017) for the Discover Media Navigation MIB2 unit - Not Pro version, that i can test out.
    The map update cannot be any bigger than 7.5 GB as this is the capacity of the OEM SD card we get from VW for our MIB2 head units.
  9. #499
    Jul 2018
    Dee Why, NSW
    Thanks again ArdiL, i did notice however that the TMC report directions are in German. Are you getting the same in your TMC reports.
    See below.
    Maps and POIs for Discover Media-inkedimg_7661_li-jpg
  10. #500
    Dec 2017
    See below.
    Yes same here with German
