new maps installed successfully.
Sent from my iPhone using Tapatalk Pro
My16 Golf Alltrack, DAP
MY18 Golf Comfortline
OK. I don't know if the Discover Media uses the same directories as the Discover Pro, so assuming it doesn't I checked if the files in the MIB2TSD directory made sense. No they didn't.
Can you try editing the metainfo2.txt file in the MIB2TSD directory so that under
[personalpoi\ppoidb\1\default\Dir]
the FileSize = "340055" line is
FileSize = "339415"
Not sure what you copied to your SD card but try the whole lot. If it fails again then just try placing the contents of the MID2TSD directory at the root of the SD card.
Lets me know how you go.
Golf R Mk7.5 MY18 7sp DSG
replaces Golf R Mk7 MY15 7sp Man that was totalled while parked😢
Yes thanks gtienvy. I figured out the file size change. But still no successful. I've only been using the MIB2TSD contents. So I've just tried putting the whole lot on the sd card. Still not good it's stuck saying it's searching for contents. I've been putting it in SD2 slot. So really frustrated why this isn't working for me. How long does the process take? Should i wait longer for it to search?
Sorry no experience with Discover Media and POI's but my Discover Pro can take a couple of minutes before it shows an error. Seems to be quicker when it works
Have you tried the file in the first post of this thread? <http://whrl.pl/RePzO4>
That one worked for me and is what I used to figure out what I needed to change/update to get my POIs to work.
What type of computer are you using to write your SD card? I use a Mac but strip the .DS_Store files when I write to the SD card.
Duplicate post
New Maps Have been released. I updated mine last night ..... ROW number is 071.
Not for my MY13 Golf yet...
Just managed to get this working for my Discovery Media. I copied the contents into several different folders so the system had no chance of not finding it.
Uploadfiles.io - MyPOIs.zip
unzip and copy to a USB.
Good Luck
