Page 32 of 51 FirstFirst ... 22303132333442 ... LastLast
Results 311 to 320 of 507
Thread: Maps and POIs for Discover Media
  1. #311
    Dec 2015
    South Yarra, VIC
    Similar problem happened on my 2016 Golf R. There was a service bulletin from USA about the version of software on the unit. It required a new head unit as old unit would not take the 3 updates the dealer tried to do. Look up my old posts as I discussed it.
    Sent from my SM-G925I using Tapatalk
  2. #312
    Apr 2011
    Quote Originally Posted by anonymous View Post
    November 2016 Map is out
    I dont have MIB1 so I can't verify it.
    Confirmed working here too.
    If anyone decides to format the SD card like I did (just to clear up the file system table I thought), make sure you select the 2048 byte allocation unit. Otherwise you'll be short of diskspace (on the 8GB card at least for me). Many small files take up more room.
  3. #313
    Jul 2007
    Is this the first year they've actually published the maps as Australia? No more downloading the South American maps etc? Wow!
  4. #314
    Mar 2015
    Warner, QLD
    Quote Originally Posted by LiFers View Post
    Nop. ROW file is still 5+ GBs and has South Africa, Asia and all the other countries VW lobs into he ROW bucket.
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  5. #315
    Mar 2015
    Warner, QLD
    For everyone's benefit. I've downloaded the 5GB file, stripped out all the useless stuff for Australia and NZ, and repackaged it. It's now a 361mb download from Google Drive, should be really quick.
    EDIT: Making it clear this is for MIB1 only.
    Also, if it doesn't work, try the following steps (thanks Herbie_059):
    "Initially, when I first inserted the SD card back into the car it sat there for ages "loading navigation ". I had to go through through the menu and select "remove SDx card safely " then re-inserted again and everything worked fine!"
    https://drive.google.com/file/d/0B85...ew?usp=sharing
    Details of repackaging files:
    1. Downloaded full 5GB of map data.
    2. Removed all market folders except AUS. This folder contains the map and voice data for Australia and New Zealand.
    3. Repacked folders into RAR archive.
    Let me know if you have issues.
  6. #316
    May 2016
    Sydney, Melbourne
    Quote Originally Posted by agentthumb View Post
    Details:
    Wow! Thank you so much !
  7. #317
    Jun 2007
    Sydney, Australia
    Maps and POIs for Discover Media-wp_20160611_10_16_28_pro-jpg
    From this.....
    Maps and POIs for Discover Media-wp_20161111_20_12_15_pro-jpg
    To this on MIB2
    Flipper Dog
    Now - T-Roc R, Audi Q5
  8. #318
    May 2015
    Details:
    It hasn't worked for me. I have downloaded the full 5GB separately. I might go back to that file and extract Aust once I know if works.
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
  9. #319
    Mar 2015
    Warner, QLD
    Quote Originally Posted by prn31 View Post
    Hmm that's strange, worked perfectly fine when I tested it.
  10. #320
    Aug 2012
    It worked for me, thanks Agentthumb Maps and POIs for Discover Media
    Initially, when I first inserted the SD card back into the car it sat there for ages "loading navigation ". I had to go through the menu and select "remove SDx card safely " then re-inserted again and everything worked fine!
    Golf R Mk7.5 2020 MY20 | Indium Grey | Sunroof | Dynaudio Excite 400W Option
