Page 45 of 51 FirstFirst ... 354344454647 ... LastLast
Results 441 to 450 of 507
Thread: Maps and POIs for Discover Media
  1. #441
    May 2014
    Richmond, NSW
    From memory you'll have to have vw install updated software on the nav unit
    Sent from my SM-G935F using Tapatalk
  2. #442
    Mar 2018
    Mcdowall, QLD
    Hey mate did you ever get to update your maps?
  3. #443
    May 2014
    Richmond, NSW
    Yes, after the firmware update, you can now load new maps as you normally would.
  4. #444
    May 2018
    Sydney NSW
    I was having no luck uploading speed cams to my MIB1 unit. After a lot of digging around on the net I did the following which worked for me, and could for some others out there.....
    1) Following the initial guide here >
    MIB II - Custom POI's / Speed Cameras etc
    2) Extract the resulting zip files (only the following ones) within the "PersonalPOI" directory, select the "MIB2HIGH" directory and extract ONLY the metaininfo file and PersonalPOI directory (with the files within the PersonalPOI directory left intact) to a FAT32 formatted USB drive (an SD card would simply not work in my case).
    Others have copied the files within the MIB2TSD directory instead of the MIB2HIGH directory to get it to work, but that did not work for me.
  5. #445
    Feb 2017
    SE Melbourne, VIC
    Quote Originally Posted by LimestoneR7 View Post
    Others have copied the files within the MIB2TSD directory to get it to work, but that did not work for me.
    Any chance you could share the POI tool as the link Infotainment redirects to a generic infotainment page. So it looks like the tool has been pulled from the site?
    MY17 Tiguan 162 Highline | DAP | Rline | Pano Sunroof | Pure White
    Stage 2.5 - APR DP, APR Turbo inlet, Muffler delete, IS38 Turbo, APR tune
    MY18 Tiguan 162 Highline AllSpace | Sound & Vision | Sunroof | Blue Silk
  6. #446
    May 2018
    Sydney NSW
    Quote Originally Posted by TheTig View Post
    I would be happy to. I used the tool a few weeks ago to create my custom POI's and only became aware today that it has disappeared when I went to book mark it for future use....
    Apparently VW Germany have done this before but the tool came back on a different part of their website. Bloody VW
    It seems they may want us to use CarNet (updates over Wifi?) which I think is not even available in Australia. Never ceased to amaze me how difficult the VW makes it for many owners to update their maps etc. I have found so many threads on overseas forms for Skoda and Seat on the same subject.
    Anyway in my extensive internet travels I found this Skoda page with the same type of web based tool. I haven't tested it though.
    http://mydestination.skoda-auto.com/...portCollection
    Someone also mentioned there is a stand alone program that does whilst not having a user friendly interface, does the job. If I find it I will definitely save it and let others know.
  7. #447
    Jan 2018
    Adelaide, South Australia
    New maps dated 25/04/2018 are available at Volkswagen Map & Softwareupdates
    Now have to wait a day for the download to complete, after 2 or 3 expected failures.
    Mk 7.5 GTI | Manual | Indium Grey | Driver Assist | Infotainment | Luxury Package
  8. #448
    Jun 2007
    Sydney, Australia
    Maps and POIs for Discover Media-maps-vw-april-2018-jpg
    Updated maps for MIB2 Discover media (Golf 7)
    Attached Thumbnails Attached Thumbnails Maps and POIs for Discover Media-maps-april-2018-jpg
    Flipper Dog
    Now - T-Roc R, Audi Q5
  9. #449
    Jul 2009
    For some reason my Discover Pro doesn't recognize the the update. I have been able to update in the past but refuses the recognize the data on the SD card. Does anyone have any ideas? Is it possible for the service department to block updates? I have VCDS, is there a setting?
    *UPDATE*
    So in the end I gave up on my Mac. I dusted off my old Win10 Laptop and extracted the archive onto a freshly formatted SD card.
    To my surprise, it worked.
    Turns out Apple's MacOS operating system has a habit of copying extra "hidden" files for things like "Spotlight" search as well as TimeMachine support files. On top, you end up with lots of tiny text files, one for each folder that have the same name as the folder only with a "." in-front of the file name. All this prevents the Infotainment system from reading the files on the SD card. UNREAL!!!
  10. #450
    Jan 2018
    No problems with my Discover Pro, but it hasn't been back to the dealer since delivery (Dec 2017).
    Download took 16 hours, no errors this time.
    Update took about 30 minutes.
    Seems a bit absurd to download a 23GB file when the data for Australia is only 2GB.
