Page 40 of 51 FirstFirst ... 30383940414250 ... LastLast
Results 391 to 400 of 507
Thread: Maps and POIs for Discover Media
  1. #391
    Apr 2012
    Kellyville, NSW
    Quote Originally Posted by Flipper Dog View Post
    Yeah you need to be careful you get the right maps.
    You may have also notice this is the Golf MK7 folder and I did say they were for MIB 1. If you are looking the MK2 Tiguan than that is MIB 2 or Discover Pro mapping depending on what system you got.
    At a guess I'll say the other maps will be released over the next couple of weeks as they all come out 6 monthly, so keep a watch out on the links.
    Oops so sorry on mobile and didn't even notice the MK7 tag!
  2. #392
    Dec 2014
    Thanks Flipper Dog. Worked perfectly. Appreciate the effort to let us know. Thank you.
  3. #393
    Feb 2017
    Newcastle AUS
    Quote Originally Posted by vwgolfer View Post
    MY14 VW Golf 103TSI with Discovery Media & V2 SD card.
    Same old issue has reappeared .... since the download only has the AUS - the green route number boxes on major roads are blank (e.g. route no B63).
    Anyone else experiencing this?
  4. #394
    Mar 2015
    Warner, QLD
    Quote Originally Posted by tlemerton View Post
    Did you use a mac? If PC, did you use 7zip to do the actual extraction?
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
  5. #395
    Feb 2017
    Newcastle AUS
    Quote Originally Posted by agentthumb View Post
    Did use a Mac to download & unpacked using 7zX.app then switched over to Win7 (using bootcamp so the card reader worked) & formatted the SD card then copied files onto the SD card less the OSX created files.
    Do I need to do the whole process on Windows side including the unpack or the whole process on OSX side?
  6. #396
    Feb 2017
    Newcastle AUS
    Solved thank you agentthumb.
    I just did it all on with Windows rather than OSX and issue solved. Route icon numbers populated.
    Curiousity ... have you been able to get safety camera POI warnings to work?
  7. #397
    Mar 2015
    Warner, QLD
    Ya I had the same problem previously with Macs. Doing it all in windows fixed it for me too
    No luck with speed cam POI as it's not supported in my MIB1
  8. #398
    Feb 2017
    Newcastle AUS
    Thanks for that .....
  9. #399
    hmm......... just found-out about VW's "Discovware" update software for navigation systems (UK site) - download versions available for both MS windows and the other one (Apple -I think ). Not used it yet, but looks interesting....!
    I've previously used the manual method -Anyone used Discovware?
  10. #400
    Feb 2016
    May 2017 MIB2
    May 2017 Map for MIB2 is out
    Direct Link to the file is here (6.7GB)
