Page 34 of 51 FirstFirst ... 24323334353644 ... LastLast
Results 331 to 340 of 507
Thread: Maps and POIs for Discover Media
  1. #331
    Aug 2016
    Chippendale, NSW.
    Quote Originally Posted by agentthumb View Post
    Map updates only I believe.
    Ok thanks.
    MK7 Golf GTI 40 Years | Carbon Steel | DSG | Front Windows Tinted | JB1 (Map 6) | Sunroof | Folding Mirrors Retrofitted | Current
    W211 E55 AMG | Previous
  2. #332
    Oct 2010
    NW Sydney
    new maps worked for me perfectly
    i saved a copy of the old maps from the VW SD card on my comp.
    "Forced induction" sounds like some sort of sexual assault.
    i drive a Golf 7R tuned by APR + exoticars
  3. #333
    Mar 2009
    Yeah, latest maps worked for me too.
    I 'think' there are more roads around my area which is a good sign.
    Also noticed my phone connects & starts up App-Connect faster....bonus.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  4. #334
    Maribyrnong, Victoria
    Maps for recent VW's Discover Pro, Media Gen 1 and 2 for Australia..Enjoy
    Hi Guys for your info all maps for VW's from 2012 on can now be found here
    VW_APAC
  5. #335
    Aug 2016
    Does anyone knows how to strip and make the file smaller for mib 2 headunit?
  6. #336
    Apr 2011
    Quote Originally Posted by roarner View Post
    You shouldn't haven an issue with filespace if you've downloaded the right file. What's the size of your SD card, and what's the size of your download? (Extracted)
    You could just remove one of the directory regions, did you format your SD Card? If so, you need to select the smallest file cluster size otherwise you will run out of diskspace...
  7. #337
    Aug 2016
    Hi Eaglehawk,
    Thanks for the reply and my bad for not explaining my intention properly..
    I have no problem with the file size and the capacity of the SD card however just thought maybe it would help the sat nav to work more efficient and faster if i remove all the unnecessary files from the card since i won't be using them anyway?
    Quote Originally Posted by Eaglehawk View Post
  8. #338
    Apr 2011
    Unless the programmers were idiots, deleting the files won't have an improvement in performance. But I can't vouch for that. Maybe it does index it every bootup?
  9. #339
    Nov 2009
    Just no. The unit will load the files it needs, and won't load what it doesn't. And regardless, more files in memory won't slow the system down unless the memory is filled and it needs to swap. Either way, deleting "unnecessary" files is not a solution that's likely to result in anything other than a broken navigation system.
  10. #340
    Aug 2016
    Sorry if my question sounds a bit dumb as i have not IT background and given that i come from Windows platform.. i always delete unnecessary files to speed up my comp .
    The reason why i started question the unit is because on and off my sat nav would go off then restart and reload the map. so i thought maybe deleting the unnecessary files would help... maybe its not the map issue but my unit needs a firmware update?
