Page 15 of 51 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 507
Thread: Maps and POIs for Discover Media
  1. #141
    Oct 2015
    Anyone with a MY16 Golf tried this new ROW 2016 update yet?
  2. #142
    Aug 2015
    Mount Cotton, QLD
    Quote Originally Posted by Mikey1 View Post
    I tried this without any luck using a V2 card and ROW 2016 maps. The navi system wouldn't move off the initial loading page and requested a valid file be used. Sort of makes sense as it's not mentioned in the step-by-step instructions that this option exists. It would be great if it did, as the "aus" folder contents are only 414 MB in size instead of 5.83 GB for the entire "markets" folder contents.
    Hey Mikey,
    I have V1, I'll have a look on the weekend again on folder contents (I'm interstate atm) and advise. But mine definitely works a LOT faster.
  3. #143
    Nov 2014
    ACT
    Hi VW_Tim, I deleted all folders except Aus and it is stuck at checking navigation. I am also interested to know how you did it.
    Regards,
    MRG
    2015 Limestone grey Golf 103TSI Highline with Luxury pack and Driver Assistance Pack II
    2012 Pantom Black Audi Q5 3.0 TDI with B&O sound system
  4. #144
    Nov 2014
    ACT
    BOOM! New "2015" maps available for discover media - free download
    Ok trick is to reset the system once the SD card is inserted by press n hold media unit power button until it resets. If it is not done and structure change from what it read before I observed it going into checking navigation data and stuck
    Single aus folder worked perfectly. Have to see if it is really fastMaps and POIs for Discover Media
    Regards,
    MRG
  5. #145
    Quote Originally Posted by MRG_AU View Post
    Regards,
    MRG
    Did you leave the 'Aus' folder within the 'Market' folder? If you don't have the market folder it won't work.
  6. #146
    Nov 2014
    ACT
    Yes it has to be there under market, the only folder in root. Coming to speed obviously it is supposed to be faster but I don't think I noticed it. May be navigating on close network of roads I may see a difference. All i wanted to know is would it work just with aus folder and it worked after reset.
    Regards,
    MRG
  7. #147
    I know it has been said before, but does the reset allow V1cards to work? Surely somebody has works out a V1 solution. Damn you VW
  8. #148
    Aug 2015
    Mount Cotton, QLD
    [QUOTE=MRG_AU;1162721]Yes it has to be there under market, the only folder in root. Coming to speed obviously it is supposed to be faster but I don't think I noticed it. May be navigating on close network of roads I may see a difference. All i wanted to know is would it work just with aus folder and it worked after reset.
    /QUOTE]
    Hey MRG,
    I should elaborate, the actual navigation isn't quicker but the entry of streets and suburbs is. Before I always had to wait for the next letter to show up, now I can "just" type. I think this is due to not having to look through so many files.
    I'm tempted to also delete the NZ files, but just haven't had the time and am happy the way it works (bar the outdated navi software).
    Cheers.
  9. #149
    Nov 2014
    ACT
    Thanks VW_Tim. Yes, I did notice the entry of street and suburbs are faster. Btw I deleted NZ entries under Aus folder and it worked
    Regards,
    MRG
  10. #150
    May 2015
    So I have a V3 card with ROW 2015 maps trying to update to ROW 2016. I've downloaded my ROW 2016 maps to my laptop and also saved a ROW 2015 back-up to my laptop.
    However when I try and reformat my SD card prior to copying ROW 2016 onto the SD card I can't because it is write-protected. What do I do? The dealer won't give me ROW 2016 but is happy to sell it to me via Spare Parts.
    I note that when I went into Navigation.com my model year (MY15) wasn't selectable so I ticked MY14.
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
