Page 12 of 51 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 507
Thread: Maps and POIs for Discover Media
  1. #111
    Melbourne, Victoria, Australia
    You deserve a beer my fellow VDubber.
    Id actually given up on ever getting a V1 update. I'm trying the part downloads as I live in Altona, Vic which has some of the worst broadband (bring back dial up. lol)
    Ill let u know how it works peeps.
    Quote Originally Posted by JR GTI PP 14 View Post
    For anyone with V1 SD you can update your map here for free!
    GPS Navigation System | HERE | Navigation.com
    This is the Naviteq (now called "Here" maps) website. I successfully updated my V1 SD card to the latest 2015 maps today. It's a big file at around 5.6 GB but totally worth the download. You will need to also download 7zip but a link is included in the website instructions.
    You need to select "manufacturer installed" for the unit and then your model details.
    To confirm, this worked with my 2013 build Mark 7 GTI with Discover Composition Media with V1 2013 maps.
    Can't recommend this download enough and happy to finally have a result for us V1-ers!
    Haven't tried this for the later versions but would imagine it would work without issues.
  2. #112
    Apr 2011
    I'm downloading this now, but things I've noticed before the download has finished:
    1. It's the same filename as the original post which only worked for V2 versions.
    2. When you select the 2014 model, it's also the same filename.
    I'll confirm my findings in a moment, but JR GTI PP 14, can you provide a photo of your SETTINGS for your SatNAV? (Device Part No.)
    Update: I can confirm that "new" link is the same file as the original post. (Same byte size anyway)
  3. #113
    Oct 2015
    Coogee, NSW
    I downloaded the 2014 year map as my Golf was a 2014 build but no luck with having it accepted. I think this was an error on my part and I should have gone for the 2013 year map as I have a V1 map currently installed. Left it downloading at home and will extract the files tonight to see if this works.
  4. #114
    Aug 2015
    Mount Cotton, QLD
    I've downloaded all versions (2012-2014), all appear to be the same. My 2013 didn't work in my 2013 model....
    DBInfo files indicates it is for part No:
    5G0919866R
    5E0051236H
    5E0919866L
    Mine is 5G0035846A
    Looks like I'll have to continue waiting (cry).
    BTW, if you want your navi to respond quicker - delete all folders bar aus in the markets folder Unless you intend to drive your car there!
  5. #115
    Oct 2015
    Newcastle (Aus)
    Guys, not sure why it isn't working for you? Worked perfectly for me....
    My system info on the DCM shows the following info (can't get pic uploaded as I'm using my phone)
    Device part number: 5G0035846A
    Hardware: 040
    Software: 0430
    Navigation database: 5G0919866R 0031 ROW 2015
    Media codec: N/A
    I used 2013 as model year and downloaded the whole map. Also it is important the file is copied to the original VW SD card (following backup on PC) and the file is saved as per the instructions. The SD card must not have additional folders otherwise the data will not be read.
    Can confirm again that my card was V1 and previous map was 2013. I've just formatted the V1 card and loaded the new map.
  6. #116
    Oct 2015
    Newcastle (Aus)
  7. #117
    Jun 2014
    Melbourne, Victoria
    Mine is definitely not working either for V1 Card P\N: (5G0919866A)
    JR GTI your card may not be a V1 card your device part number seems to indicate - doing some forum research below it is later build than our V1 cards Part No - from this post anyway, the V1 Cards seem to be supplied starting in the first build MK7 Dec 2012 timeframe
    ________
    On my Oct 13 build MY14 103kW Highline, I clicked on "system information" while in navigation mode and the following was displayed:
    Hardware: 040
    Software: 0421
    Navigation database: 5G0919866A 0022 ROW 2013
    ___________
    And as VW_Tim mentioned the file name and download is exactly the same as V2 cards mentioned in first post - on the download page is mentions that its a 5.7 Gb download yet download was 4.6 Gb so i wonder if the wrong file is being supplied on download site also
    Very frustrating for sure - was this close it seems
  8. #118
    Jun 2014
    Melbourne, Victoria
    Also studying the download links and website its exactly the same website as first posted in this thread just renamed to Here Maps
  9. #119
    Oct 2015
    Coogee, NSW
    2013 year map was a no go also. Followed the instructions to the letter but the screen displayed the dreaded 'The navigation data in the infotainment system are not valid. Please check data.' Reloaded my back up V1 and I'm back to original.
    My SD card is part number 5G0919866A.
    2015 DB info is for part number 5G0919866R
    system info with v1 map installed is:
    Hardware: 040
    Software: 0421
  10. #120
    Hm............ can anyone who has successfully updated their V1 SATNAV confirm that the flle structure and file sizes from the download are the same as shown in the picture below (total download size = 4.46 GB for the 5 x files)
    Thanks in advance
