Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Light Assist with Halogen Lights
    May 2019
    Perth, WA
    Hi Everyone,
    I'd like to explore the possibility of configuring/coding Light Assist/HBA on my Golf Comfortline which comes with halogen headlamps. It does have the DA package though. Currently I can see "light assist during rain" as an option.
    Any thoughts?
    Pacific Paradise QLD
    You might get High beam assist(Auto dimming) but dont think you can get DLA with halogens
    May 2019
    Perth, WA
    Hi Hillbilly... Always to the rescue!
    I meant Light Assist (HBA). I'm aware DLA works only with the LED headlamps & AFS.
    What would be the coding for LA/HBA? I've seen several codings available but they mention to select bi-xenon with shutters installed & I dont have xenon headlamps but halogens
    What are you using to code it There is an App in OBDeleven to do it that seems to work
    May 2019
    Perth, WA
    nibose: Not sure that I really understand what you are asking -but you may be referring to AFS, (Advanced Frontlighting System)-dynamic cornering light. High bean Assist - which is the system whereby the front facing camera detects an on-oncoming vehicle and then modulates the high-beam function needs special equipment (a front facing camera for starters).
    Even true AFS is not possible with standard OEM Halogen fittings - this is only possible with some HID assemblies. But - it is possible to implement a form of ASF called Static AFS with Halogen fittings. But you need front fog lights - does your car have these?
    Static AFS is where the fog light on the side of the car where it's turning is switched-on. Is this what you mean?
    THat seems to be a Canadian site May not work here but look familiar
    Gor here and look for the HBA coding in Mk7 guides
    AutoInstruct – The Home of Automotive Guides and Products
    May 2019
    Perth, WA
    I'm asking for High-Beam-Assist or Light-Assist, NOT Dynamic-Light-Assist.
    My headlamps are halogens and there's no AFS. I do not intend to have AFS either for that's not possible with the current setup.
    @ HillBilly: I cant seem to find HBA coding in the link
    Dec 2010
    Helensburgh
    It might short cut things if we forget the acronyms, what do you want to do, is it dipping the lights automatically depending on the traffic conditions?
    HBA is auto dimming when on coming traffic
    DLA is when the LED lights part to put a car in front or oncoming in a dark spot but stay on high beam
    Its in this link but dont know if it works for your model as thats the Tiguan list but it worked for me
    All care no responsibility Volkswagen MK2 Tiguan OBDeleven / VCDS Tweaks List – AutoInstruct
    Try at your own risk
