Results 11 to 20 of 22
Thread: Light Assist with Halogen Lights
    Dec 2010
    Helensburgh
    Yes I know all that but what does the OP expect? VW over the years have used many acronyms for many features of headlight control and many of them were still used when those features changed.
    Pacific Paradise QLD
    DV52 will know for sure but I reckon the most he can expect would be HBA where the lights dip at oncoming cars and only if the car has the camera in the front of the mirror that detects them. HE should look and see if it has that first
    May 2019
    Perth, WA
    Hi Hillbilly,
    Thanks for the settings, will try it out, though am pretty sure will need to do some tweaking as the mentioned settings require AFS.
    1. High Beam Assistant - Menu Control High Beam Assistant - Change to 'Present'
    2. Highbeam_assistant - Extended_airbeam control - Change to 'AFS, FLA, Highbeam via AFS'
    May 2019
    Perth, WA
    I tried to code the car today. The coding I have is:
    Enable Auto High Beam (Light Assist)
    Enables the Auto High Beam for Highline Models Only.
    Select Control unit 09 (Central Electrics)
    Security access
    Access Code 31347
    Adaptation
    1. Fernlicht_assistent – Menuesteuerung Fernlichtassistent – Change to ‘Present’
    2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’
    Enter Coding
    Byte 2 – Tick Bit 0 and Bit 1
    Select Control Unit Front Sensor Driver Assist System (A5)
    Enter Coding
    Byte 21 – Tick Bit 5
    Reboot Headunit. Option will now appear under ‘Light Settings’ and pushing the high beam stalk forward will reveal the symbol with an ‘A’ within it.
    However, I cant seem to code central electronics (09) byte 2 or any byte as the entire coding is displayed as "zeros" . All the other control modules display the coding in numerical or hex. I'm using the latest version of VCDS (bought it two weeks ago - official).
    Any thoughts?
    Light Assist with Halogen Lights-bcm-jpg-jpg
    nibose: Sounds like you have a mk7 that's post MY16. The good Burghers in Germany that design control modules made some fairly drastic changes to the BCM around this time. The mods started with a change to the "parent" name of many of the adaptation channel groups. After that, further changes were made to the hex09 module in that the software switches in the module's long code were transferred to adaptation channels - making the already huge channel count in the module even larger.
    That's why the long code on your BCM is a zero-string (i.e. all of the Byte/Bit functions are found in Adaptations -10 in VCDS).
    So - to the instructions in your post. Here is the pre MY16 long coding helper screen for Byte 2 in the BCM:
    Notice that the wording for hex05 in my picture above is fairly close to the adaptation channel in your instruction:
    2. Fernlicht_assistent – Erweiterte_Frenlichtsteuerung – Change to ‘AFS, FLA, Fernlicht ueber AFS’.
    This suggests that the Byte/Bit instruction further in your instructions has already been accommodated in the adaptation change steps
    But as they say at NASA "Houston we have a problem". The superfluous Byte/Bit instruction (i.e.
    Byte 2 – Tick Bit 0 and Bit 1) results in a value of hex03. BUT, the adaptation channel part of the instructions yields a an equivalent value of hex05 (see my picture).
    May 2019
    Perth, WA
    I did manage to get HBA enabled. I now have the option available in the infotainment centre and moving the stalk makes this option available. Please take a look at the pictures. I will have to wait till evening to try this out.
    Interestingly, I did get an error code when I did an autoscan - error message posted below. This seemed to disappear when I cleared the errors, took a tiny test drive and performed the autoscan again. Hope it doesnt return. Any thoughts?
    09-Cent. Elect. -- Status: Malfunction 0010
    FLA_01 datenbus fehlende botschaft ==>Missing Databus error
    I'm sorry the save function did not work properly, hence I'm not able to post the correct error codes.
    Here are the codings I'd performed:
    Light Assist with Halogen Lights-hba-1-jpg
    "NOT PRESENT" value changed to "PRESENT"
    Light Assist with Halogen Lights-hba-2-jpg
    "Basis" value changed to "Basis: FLA" I chose this option since my car does not have AFS
    Light Assist with Halogen Lights-hba-3-jpg
    New Option: 20 - AFS_Coding_Light_Assist_High_Beam_Assist
    Please let me know if I'm missing something here.
    To be honest I found it wasnt all that great On the motorway with side lighting it tended to dip because of the bright lights
    Now I have DLA , HBA doesnt seem to be coded in and so wont work which wont upset me as its pretty easy to flick the lever.
    Ive had the car for 6 months and only driven at night once and not since i enabled DLA so dont know if its any good or not.
    May 2019
    Perth, WA
    Well, something's better than nothing.
    They are ostensibly different versions of the same thing:
    • Dynamic Light Assist (DLA) is an analogue version which integrates dynamic cornering light (AFS) and dynamic main beam control (MDF) functions so that the headlight range is continuously adapted as the car approaches another vehicle/light structure
    • whereas Main Beam Assist (FLA) is a digital (or more accurately described as a "binary") version in that it enforces a sudden switch between high beam and low beam.
    I'm quite surprised that you have managed to enable DLA by simple coding. DLA headlight fittings generally include a group of individually moveable screens which can be swiveled into the light cone (i.e. the HID discharge envelope or the LED window) cast by the high beam lamp. The DLA function (i.e. the partial masking of certain areas of illumination as the car travels) is implemented through a combination of the screen switching and the horizontal adjustment of the lamp itself.
    VW is renowned for providing only the bare essentials in their cars where physical equipment is concerned (i.e wiring looms are just sufficient - no more). It's lucky that your car was provided with DLA equipment if the function wasn't coded at the factory
    The Tiguan162Rlines (at least) and the Allspace's have the same headlights. The Allspace has the Full DLA standard in the Driver assist package
    The 5 seater doesnt A Poster on here Phonebooth provided the coding instructions for DLA and it works using an OBDEleven.
    I did ask about it on the OBDII forum but didnt get a reply It doesnt do what the Audi matrix lights do but it does blank out parts of the area
    This shows the light pattern on startup
    Light pattern.mp4 - Google Drive
