Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: LED interior light upgrades
    Jun 2016
    Sydney, 2224
    MK7 Boot Light LED?
    Hi,
    Was wondering why I had no light in the boot, pulled out the light assy and found the bulb blown.
    Seems like most people are replacing the standard bulb with a LED, so I might as well get one to match the other interior LEDs in the GTI.
    Was thinking this one might be the go http://www.ebay.com.au/itm/1X-41MM-33-SMD-3014-LED-Car-Festoon-Bulb-Interior-Dome-Light-License-Plate-Lamp-/231941948932?var=&hash=item3600d14604:m:mWjfMpFhn4 zCUAruAkI7mQA&rmvSB=true
    Any input to what others are ordering would be great, thanks
    Sep 2011
    Any LED that fits will do as they don't trigger any light warning. At least that's my experience.
    May 2013
    Quote Originally Posted by DKC View Post
    Yeah, although I found the cheap ones on eBay had poor connections and had a habit of flickering. I eventually replaced all of my cheap ones with better quality bulbs from Bold Sport.
    MY08 Mk5 GT Sport - sold
    Jun 2016
    Sydney, 2224
    Thanks, I've ordered a cheapy off eBay, will let you know how it works out
    Aug 2012
    Quote Originally Posted by stellio78 View Post
    Hi,
    Just ordered an LED globe for the boot, too.
    Here's a link to the one I bought (mainly because it was coming from Sydney so postage would be quicker)
    The existing globe hadn't blown but it was pretty weak. Barely enough light to see anything in the boot.
    I'll post a guide on how to remove the fitting and replace the globe once the globe arrives (even though it is ludicrously easy).
    MY16 Golf GTI Performance Pack
    Previously: MY12 Polo 77TSI
    In The Family: MY15 Golf 103TSI Highline & MY15 Audi RS3
    Mar 2015
    Warner, QLD
    Quote Originally Posted by Barracuda View Post
    Would be much appreciated if you did
    Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
    Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
    Aug 2012
    Quote Originally Posted by agentthumb View Post
    Will do! The LED globes should arrive tomorrow or Thursday so I'll do it as soon as they arrive.
    Aug 2012
    GUIDE: LED Boot Light Upgrade
    I'm sure everyone will agree that the stock halogen light in the boot of the Mk7 Golf is pretty miserable. It's only bright enough to light about half of the boot area. It's also slightly annoying that the boot light is halogen when the rest of the interior lights are LED (Highline, GTI & R).
    Luckily, there is a solution and it's cheap and easy.
    What you'll need:
    • Flat-head screwdriver
    • 41mm Festoon LED globe
    I used this 41mm Festoon LED globe from eBay. You can use any Festoon LED globe as long as it is the correct size and voltage.
    1. Remove the light fitting from the trim. You'll see a small cut-out on the side of the light fitting that is closest to the boot opening. Use a small flat-head screwdriver to push in the metal clip which holds the light fitting in place. Alternatively, use some trim removal tools if you have them.
    LED interior light upgrades-removefitting-jpg
    2. Detach the power cable from the light fitting by pressing inwards on the two clips as shown below.
    LED interior light upgrades-releaseclips-png
    3. Remove the stock halogen globe from the light fitting by pushing on the side of the globe until it slides out of the terminals.
    LED interior light upgrades-fittinghalogen1-jpg
    4. Install the new LED globe and ensure that it is facing the front of the light fitting.
    LED interior light upgrades-fittingled1-jpg
    5. Reconnect the light fitting to the power cable and ensure that the clips on the power cable are secured. If you're lucky and the globe is installed the right way around, then it should turn on straight away. Otherwise, remove the globe, turn it around and re-install it.
    6. Re-install the light fitting to the plastic trim and you're done!
    Before:
    LED interior light upgrades-before-jpg
    After:
    LED interior light upgrades-after1-jpg
    The only issue that I've come across is that the globe remains on (albeit, very dim) when the boot is closed. Apparently this is normal for some LED globes and is due to the fact that they're so much more efficient than halogen globes and the small amount of residual voltage is enough to power the LED globe in a very dim state. Strangely, when you lock the car the LED globe will turn-off completely.
    Here's a photo of the LED light when the boot is closed:
    LED interior light upgrades-ledoff-jpg
    Apparently, it won't cause any drain on the battery...
    Anyway, I hope this guide helps anyone thinking of doing this great little modification.
    Sep 2011
    I was going to make a post about boot light upgrade as well! In my case I have the R Wagon and the stock halogen light is in the roof, and grossly inadequate. Particularly if the luggage cover is drawn, there is no light underneath!
    So in addition to fitting a 41mm LED festoon (from ebay), I connected a strip LED. It's powered by the same roof light so they turn on and off together. The strip LED is stuck to the vertical divider mesh metal bar across the boot just behind the rear seats (which is separate to the luggage cover).
    Actually does anyone know whether this very solid metal bar is just for the vertical luggage divider mesh to be pulled out, or does it have a performance function? Like a strut brace between the 2 rear struts?
    LED interior light upgrades-img_4206-jpg
    The tiny row of dots on the floor of the boot is artefact from the camera. See how weak the roof LED is by comparison!
    LED interior light upgrades-img_4209-jpg
    Self frabricated connector to attach the wire to the ends of the LED Festoon
    LED interior light upgrades-img_4224-jpg
    How it looks connected
    LED interior light upgrades-img_4221-jpg
    Aug 2012
    What an improvement! That light bar looks brilliant! Do you find that the Festoon LED globe that you installed in the ceiling light stays lit in a dim state when the boot is closed?
