Originally Posted by
DKC
The tapping into the roof light was a simple plug and play if you can find a thin piece of metal like I used. it simply fits between the festoon and the metal connectors, adding may be 0.2mm to the length of the festoon. Then threadin the wire around and down is quite easy too, as for most of the length I could just push the wire into the gap in the trim. Having car trim tools help.
I thought about putting the LED strip on either the Divider Mesh Crossbar, or the lighter horizontal luggage cover bar. Since I usually leave them both in the car, either would do. But I did also think about putting the light on the side which would work as well.
