Results 1 to 2 of 2
Thread: Late Changes in sport mode
    Jun 2018
    Hi all,
    I've just picked up a second hand 2015 GTI Performance DSG - my first automatic - and it's a fantastic car, much quicker and more fun (but heaps less efficient) than my old 90tsi. My only concern is that when I slip it into sport mode and floor it, it seems to rev to the limiter (and the acceleration slows down a fair bit). Essentially, on full throttle, it revs up to ~6500-7000RPM, then the revs stop increasing for just a moment before it changes gear (the change itself is fast, just the timing seems off?). It seems to do it from 1st>2nd and (maybe slightly less so) from 2nd>3rd. I've not been fast enough to experience 3rd>4th at open throttle, so can't comment on that. It just concerns me, because if slipped into manual mode, it has no problems (and feels quicker), but I would've imagined the full-auto should be faster than manual mode?
    For a bit of context, the car has 61,000km, has had the big service completed by VW, is always fully warmed up when this happens, BUT, the tyres aren't the best (they're new, but Hifly brand, so I'm not sure - could it just be wheelspin causing this?)
    Thanks in advance!
    Apr 2017
    belgrave victoria
    This is a common problem with the dq250 6 speed gearbox you have in the car
    The gearbox hangs on way to long in sport mode revving the tits off it in every gear and it changes up way to early in normal drive mode even if your prodding the gas pedal
    The solution is a dsg tune it will give you more flexibility in drive and a much better change in sport mode
    Oh and remember its NOT a automatic its a computer controlled manual treat it as such i.e don't hold the car on hills on the throttle ect treat it like a manual it has clutches that will burn out like a manual if mistreated
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
