Results 1 to 10 of 12
Thread: mk7.5 GTI - Sound system options
    Jul 2011
    Aust
    Hi,
    This probably should be in the audiophile section of the website but I'm not looking for turning the car's audio system into a setup that ends up costing $1000s and $1000s and I'm hoping some more learnered members of the forum could weight in with some reasonable options
    The car has the standard sound system from factory (Discover Media). When the teenager plugs in and plays her music the sound coming out can be grating and unpleasant like fingernails on a chalkboard, if there's any members remember those.
    I'm not sure if a straight factory fit speaker upgrade would be sufficient to offer a significant upgrade on the sound quality or of the headunit isn't capable and it would require a change of that and then an amp at which point I think I'd just leave it the way it is.
    I'm not sure if it would economical to upgrade the entire system to the factory Discover Pro.
    Note: I didn't go down the Discover Pro from new as it also came with a sunroof in 2020. Something I'm very much anti of.
    May 2007
    Focal Inside would be a very good option; VW Golf VII | compact (2012-2020) | Au Auf | Focal Inside
    Aug 2021
    I can highly recommend the Kicker Key 200.4 amp as a fantastic upgrade, even whilst retaining the factory speakers (I'll be fitting aftermarket speakers soon, although if I hadn't already bought them, I'm not sure that I would have bothered). The extra power, plus the application of equalisation and time alignment via the supplied microphone significantly improves all aspects of the sound, and works wonders on the sound staging and imaging.
    I had the Focal IS VW 155 speakers in my Mk7 GTI and they were a great upgrade for the money in my opinion. Depth, clarity and overall sound quality improved noticeably. I bought them from a shop in Germany called extremeaudio and they were about 40% cheaper than buying locally.
    The speakers are made specifically for the VW Golf so they plug straight in and fit perfectly. The only little modification was to the tweeters but that was not hard to do.
    I also purchased the Impulse 4.320 amplifier and the IBUS20 subwoofer, but never got around to installing those - and the car is now sold - so i will be advertising the amp and sub soon for sale.
    Jul 2011
    Aust
    The IS VW 155 is just the front speakers yea? that how I'm seeing the product. And yea that's a big saving! $499 RRP here. There's one site I saw for $330ish? but I need someone (trustworthy) to install.
    Did you add their sound deadening as recommended?
    Jul 2011
    Aust
    Hi Lucas - Do you put IS VW 155 in the front and back?
    There's an alternative option of IC V 165 for the rear and I'm struggling to work out the difference (apart from the lack of the tweeter in IC VW 165)
    Aug 2021
    Quote Originally Posted by minke View Post
    The IC VW 165 has a tweeter, but in a coaxial (centre mounted) arrangement, rather than a separate/split arrangement.
    If you want to do front and rear speakers then you will need to purchase 2x of the IS VW 155 sets (which will be 4x mid range speakers and 4x tweeters in total). This is what I had in my car.
    And yes I installed sound deadening extensively when replacing the speakers (as well as doing the rear hatch, spare wheel area and under the rear seat) but I didn't use the Focal sound deadening - I used this product which I was happy with:
    BIG DOG SOUND DEADENING ROLL
    Jul 2011
    Aust
    Thank you. Is the sound deadening really going to be noticed? I've watched the Focal install videos on YT adding the sound deadening to the doors and too me I cannot see how that is going to help the audio (clarity of the sound).. ?
    I have used sound deadening on a few cars now and it reduces road noise, external noise, vibrations and rattles etc. So it makes your stereo sound better from making your car quieter. That's my experience anyway.
    I'll be buying a new car in the next few weeks and will more than likely do sound deadening again as its relatively cheap and I have found it to be quite effective - especially for the price.
