Uuuhh i fail to see how that is in any way easier? yes i have the vry small a with a slash pop up but it also took less than 30sec of my time ok it cost 70 bucks(cost saving over your method if you add in hrs minimal) but it is also reversible in the same amount of time, is your hard wired mod that easy?
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
Some people just don't appreciate good engineering when they see it
(I love your solution, it's the way the car should have been made!) - But I'm sure some stupid ADR rule made it "illegal". (fuel consumption?)
Oh dont get me wrong i appreciate what he has done i would not be able to that at all (blessed with 10 thumbs)
It's just that i dispute the easier part taking apart console and soldering bits into the wiring is imo not easier or quicker than a 15 to 30 sec plug and play system... even if i have to live with the vry small a with slash (which i do not even notice on digital dash unless i look for it)
Also if necessary i can undo change in same time for any dealer related warranty issues ect then reinstall after so yeah i like my solution better does not make the complex system bad i am impressed with it and the knowhow that has gone into it but its not for me
Update on the kufatech module
Took car to dealer for 1000km check up took me about 1 min to enable start/stop and another 1 min to get rid of it again when home again
Highly recommend this item works like a charm
Generally, I don't like the dongles that stay connected to the OBD port or the can bus system indefinitely. If something goes wrong with them, you never know the extent of the damage it may have.
...and yes, I had a car which refused to start not long after it had the aftermarket (known brand too) device attached to the can bus unit.
So, the thumb up to the people like Don (DV52) for their excellent work.
Yup your spot on Transporter it reads your vin number and is locked to that car only you can use it unlimited times but only on that car
So you gotta spend another 70 bucks for a new unit if you have 2 cars that need it still worth it tho just the drive down to dealer and back was enough with it activated could not wait to turn it back off
