Originally Posted by
joshcrd
just to clarify
if I get the A symbol using the kufatec, I can just switch it off before the service, the A disappears and the dealership is none the wiser?
Yep that's it just remember to do it before you take it in. Drive it there with the stop/start activated and you will remember why you took it off
The a symbol with the slash through it only comes on when stop/start would normally be activated (you get the same symbol if you press the deactivate button when you start up) so when you pull up and the car would normally stop the little a with slash pops up and goes away again when you move off
2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
