Originally Posted by
knightsy
Has anyone in Oz done this tweak? The VCDS link is to VWVortex and I could only find North Americans having done it. Is it legal here? I am going to have a few tweaks done shortly and thought I might include it.
Thanks
knightsy: Hi and congratulations on your (imminent) new car. I'm not sure if anyone in OZ has done the tweak and I'm equally unsure of the legality of your change, but it isn't difficult to do what you want (IMO).
I can tell you how it's done for my 103 TSI (incandescent DRLs), but I suggest that you first make an adaptation map of the BCM on your new car (when you get it) and compare your default settings with mine.
OK , the Leuchte channel-sets that control the DRLs are
- Left DRL - Leuchte4TFL LB4
- Right DRL - Leuchte5 TFL RB32
On the Aussie version of the Highline (ROW model), the DRLs perform the following 4 x functions
- Normal DRL
- DRL Wink
- Parking Lights
- DRL Single Side Park
I've shown below the complete Leuchte-set for the two DRLs (on an Aussie 103TSI) and I've also Identified which Aplha-channels have been programmed to perform each of these four functions:
So if you want to disable DRL Wink, you simply change
( 8 )-Leuchte4TFL LB4-Lichtfunktion C 4 and ( 8 )-Leuchte5 TFL RB32-Lichtfunktion C 5 to not active - and DRL Wink is gone (it's that easy)! Because there will be no "active" function in the Leuchte sub-set once you have made this change, there is no need to alter the association dimming channels - so you can leave adaptation channels (10) & (11) as they are.
PS: coincidentally, I've just been working with a colleague on a well-known US forum in developing a tweak where we have turned DRL "Wink" into DRL "Blink"! This is a tweak where the DRL blinks together with the turn signal (instead of turning-off) on the chosen side of the car (or, on both sides of the car if the safety flashers are engaged). Looks real cool, but I'm not sure how legal it is (both in the USA under their Fereral DoT rules, or down here under our own ADRs). I haven't included the tweak instructions on this forum for this reason
