Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 115
Thread: Incorrect Speedometer - Golf mkVII?
  1. #21
    Jun 2009
    team_v/brad: great minds think alike! Thanks both for the info. If I can extrapolate the content of your respective responses, this means, I think that as the tires on my car wear, the I accuracy gets bigger (but only marginally, I hope)
    Brad is one of the resident tyre experts on our forum.
    As the tyres wear down, your rolling diameter decreases so the speedometer will read lower still.
    So if you start off with a 6% error (speedo says 100 at 106km/h) then you might see it push out to 7% with tyre wear (speedo says 100 at 107km/h)
  2. #22
    One thing that you have to keep in mind is that car makers have factor in people going either 1 size up or 1 down on tyre size. So they'll generally set the speedo to be around mid-range of what is acceptable by ADRs so that if the owner does change their tyres they are still within the allowable limits.
    Which puts you 6km/hr out at 100km/hr.
    Probably the best thing you can do is "calibrate" your speedo with a GPS based device. So you know what your actual speed is relative to the indicated speed.
    ...and then hope that the speed cameras are all calibrated accurately and installed correctly also
    Erskineville, NSW
    I look at the difference between actual & gauge reading as being similar to those folks that try & fool themselves to getting to meetings on time by setting their watch ahead of the real time (I have a friend who is smart enough to have a Doctorate but sets her watch 30 minutes forward to trick herself.)
    Since I got my speedo to a 1=1 status I rarely exceed the speed limit. I actually treat the speed limit as a limit (maximum) rather than "this is the speed you should have the speedo on". It still means I'm driving faster than many other road users.
  4. #24
    Jun 2009
    I find the same thing.
    Makes you realise all those people who think they are being safe by doing 90 in a 100 zone are just dawdling becasue they are really doing 85.
  5. #25
    Dec 2008
    Sydney/Canberra
    Check your odometer as well because that is also dramatically wrong - but not the full 10%. I think I worked out that 15,000km on the odo was only 14,300km actual, so you get services done earlier than needed & when you go to sell your car the recorded mileage is much greater than the actual milage. I guess the ideal situation would be to make the odo close to 1=1 & that will sort out the speedo with a bit of safety margin still available.
    I recall a service bulletin from Volkswagen Group Australia that refutes this, as it is measured based on the car's "true" speed, not the "corrected" speed displayed on the speedo.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  6. #26
    Jan 2010
    Condell Park, NSW
    Quote Originally Posted by Umai Naa!! View Post
    Indeed... And it's quite easy to measure odometer accuracy using the odometer check signage on some motorways - they only go for 5km each but 10% of 5km is still 500m and the odometer is a lot more accurate than that..
    As for checking the speedo itself - if you don't have a GPS handy this works well at getting the uncorrected speed out of the car..
    - Set the cruise control to the speed you want to check, say 100km/h
    - With the vehicle at speed reset the trip computer
    - Select the average speed readout
    - Initially it will show dashes but after a few seconds the average speed is shown which is the uncorrected speed and actually quite close to GPS speed..
    For cruise control at 100km/h I get 94km/h
    - Anthony.
    VW Tiguan 110TSI Life | Tungsten Silver
  7. #27
    Quote Originally Posted by hoi polloi View Post
    - Anthony.
    Anthony et al: is it just me, or does anyone else find all this strange. What's being said is that the car actually knows the correct distance that it travels and the car also knows correct time. But for some odd reason, the car can't/won't tell the driver the correct speed. Doesn't this seem just a little bit absurd? Why would the good burghers in Germany take these correct metrics and manipulate the speedo reading to give the wrong number?
  8. #28
    Dec 2008
    Sydney/Canberra
    Take a moment to think about how speed limits are structured in the car's country of origin.
    If they didn't have to take over countries and their laws into consideration, they wouldn't print anything above 80 on the speedo.
    '01 Beetle 2.0
  9. #29
    Arrawarra
    ...The fact that all those other cars kept passing me suggests that their speedos were more accurate...
    Maybe they were all just aware that their speedos were out by a known amount. I set my cruise to 118 when I'm on the freeway, 107 when I'm on the highway.
  10. #30
    Pacific Paradise QLD
    The ADR rules in Australia state that all car speedos may read faster than actual by up to 10% +/- 4.
    It may NOT read less than actual speed
    The odometer is not affected and should be accurate as to distance travelled
    My Polo is 7 over the Passat is 6 and my Landcruiser was bang on at 100kph
    Also I worked out to bring the Polo correct would take a size of about 40mm diameter larger.
    This would be illegal as most states only allow up too 26mm larger.
    It would also seriously overgear the car and make it a lot slower off the mark and put additional strain on the DSG
