Originally Posted by
NCGR1
All manufactured devices have tolerances. In the case of the speedo in a car, there are a lot of items that all have a tolerance to be considered. No car can leave the factory indicating lower than actual. Certainly calibrating each and every vehicle at the end of the line would not be practical.
I really don't see the problem here. You know that the indicated is a bit high from actual. Make the adjustment in your hear if you just have to be traveling exactly the speed limit.
NCGR1: thanks for the advice. I'm constantly having to make the mental calculation that you suggested to correct for the inherent error in my speedo. In fact, I'm quite proud of how good I've become at doing this because I can now do the calculation without counting using my fingers - very handy because I no longer need to take my hands off the steering wheel! (Just kidding)
My point (which i didn't make clearly enough) is that the process that is being used for speedo calibration on modern cars is a "nanny" protocol. Yes it's being driven by local legislation like the ADR and by the threat of litigation that seems to be rife everywhere.
IMO, a far better approach would be to leave the responsibility for keeping to the speed limit entirely on the driver (and to have the speedo read accurately). I suggest this because ultimately there can be only one person who can be accountable for this function.
For me, the one vital question on this matter is this: why should the driver be forced to make the mental calculation that you suggest to figure out how fast the car is really going? Isn't this the sole purpose of the speedo?
And then there is this other question: if it is really necessary to have speedos in Australia under-read by an amount for safe driving, then why not simply change the speed limit to this quantity? Why have the speed limit sign say one thing- and then force car manufacturers to set their speedos to say another thing? Doesn't make sense to me.
Anyhow, I'll now get off my soapbox. Thanks for listening
If you look at the rich functionality of the options that
