Results 1 to 10 of 11
Thread: How to turn radio off ?
    Dec 2015
    NSW
    Seems a simple question. Hope there's a simple answer.
    Sometimes I'd like to turn off the radio, without turning off the media unit completely. (Discover Media, Generation 2)
    How to keep the navigation on, with radio silence ?
    Sometimes when having a conversation with a passenger, we'd like no radio, BUT still be able to hear the occasional turn-by-turn navigation instructions. So turning the volume down to zero is not a solution.
    My car had its first service last week. Sadly I didn't ask the expert technician.
    Current : 2017 Mk7 Golf R (most options) || 2012 Golf Mk6 TDi (few options)
    Gone : 2004 Bora V6 4Motion (few klms, all options)
    May 2013
    I’d just select Media and not set anything playing.
    Sent from my iPhone using Tapatalk Pro
    MY08 Mk5 GT Sport - sold
    Apr 2009
    Melbourne, VIC
    Turn the volume right down.
    May 2009
    Perth, WA
    I am sure that turn by turn direction have a separate volume level you can control. So if you turn down the radio volume the TBT should still be heard. Will have to test to confirm to see if it is a system level or radio volume.
    Jul 2009
    Without sounding smart but have you consulted the manual???
    Dec 2015
    NSW
    Well team, thanks for suggestions.
    Turning the volume down also mutes the turn-by-turn directions.
    I tried selecting media, but it seems to insist on playing the next track from SD card.
    Yes, I did read the fine manual (RTFM). I'm one of those old-fashioned types that usually reads a manual cover to cover before turning the device on.
    I will also go read it again, just in case there's a hidden gem lying quietly in those pages.
    Only way I can get this to work as desired is to use Android Auto, select an audio stream, then hit pause.
    That shuts the device up, while still delivering navigation instructions.
    Message to VW : It should NOT be this clumsy. Opportunity for improvement exists. Low hanging fruit. Yadda yadda.
    Jan 2018
    Adelaide, South Australia
    Tested it this morning with Discover Pro 2 on the way to work.
    Mute the radio, and check that the "Announcement" volume on the nav screen is not muted.
    Mk 7.5 GTI | Manual | Indium Grey | Driver Assist | Infotainment | Luxury Package
    Nov 2017
    Coffs Harbour NSW
    In my Golf I just tap the power button and it stops the music/radio, whatever I'm listening to. If I hold the power it shuts the system down completely.
    Although I generally just put it into SD Card, BT or CarPlay and hit pause.
    Oct 2016
    I’d actually prefer an on/off knob to kill the radio much quicker to be honest.
    Apr 2009
    Melbourne, VIC
    Radio is like an "app" in the multimedia centre. It's not a separate unit.
    There needs to be a programmed "Radio Off" option, like shutting down the radio "app" part of the system while leaving everything else running. Shouldn't be hard to program.
    Add it to the list along with a mute button on the steering wheel and the ability to reposition the touch screen menu options like repositioning apps on a phone.
