Page 13 of 27 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 270
Thread: Headlights - Discussion and Questions
  1. #121
    Mar 2014
    Perth, WA
    Quote Originally Posted by AdamD View Post
    Before you start thinking about cornering lights and configurations, let's cover the basics:
    Are you referring to the standard headlight operation only? Or also foglights, high beam, etc?
    Have you confirmed you don't have any bulb issues? Does the right bulb appear dimmer than the left?
    AdamD, no I haven't done any of those things, the car is brand new. Its low beam I am talking about (dont have fog lamps). The lights look equally bright from the outside. It is so bad that I would have thought that if it was a general problem that everyone would be having the same issue. Best way to test is drive along a road and turn right into a turning that has a skinny median strip or island in the middle. I cannot see anything on the right of the vehicle as I am approaching and turning into it.....
    Car is going into dealers to get 'airbag' light fixed. Will report it then
  2. #122
    Jun 2014
    NSW
    Quote Originally Posted by flashman1207 View Post
    I'm pretty sure I don't have fog or cornering lights..... Anyone else with a Comfortline out there that can confirm?
    Wouldn't be doing 50km/h at a t-junction. Would be still
    My 90TSI Comfortline mk7 has no cornering lights or fog lights in front. The stock halogens are very weak, made worst because I am used to bi-xenon from previous cars.
    I changed them to Philips Xtreme Vision which improved things greatly. Still nowhere as good as xenons but I believe it's one of the better alternatives available.
  3. #123
    Mar 2014
    Perth, WA
    Quote Originally Posted by slashj View Post
    Have you noticed the same problem as me though? and if so did the new bulbs improve things (cant see how they could as it seems to be the reflector)
  4. #124
    Apr 2011
    Page 113 of the manual. It's 40km/h for the static cornering lights...if you've got it...also turns on when in reverse. Duh?
  5. #125
    Mar 2014
    Perth, WA
    There are no cornering lights on Comfortline model as standard. The very fact that they are provided on a Highline surely indicates that they are needed. Why else ?
  6. #126
    Mar 2014
    Perth, WA
    So the wife takes the car to the dealer and gets told there is nothing wrong with the lights (apparently they 'checked' them). So the fact that I nearly crash the car every time I turn right when its pitch black has something to do with my wife and my eyesight? Strange that my eyesight works just fine in my other 2 cars, one of which is 20 years old
  7. #127
    Jun 2014
    New Zealand
    To be honest there isn't much you can do about the headlights other than upgrading the bulbs, others have commented on the Halogens not being particularly good and I found them pretty week with the stock bulbs on a loan mk7.
    There has been pretty good feedback on various forums regarding upgrading the bulbs and that really is your best bet.
    I assume the intersections you are having issues with are not street light illuminated?
    I've been hanging around a few mk7 forums for almost a year and yours is the first complaint I've seen regarding lighting/turning issues so it isn't a common complaint from my observations, your local and poor street lighting could be a factor?
    Go for the bulbs, it could be a game changer for you.
    Good luck and regards.
  8. #128
    Oct 2013
    Melb, Vic
    I fitted the Osram night breaker bulbs $30 from Powerbulbs you can see the difference here when I fitted the first 1 to the RHS its a lot "whiter" and brighter. It may not solve your unusual problem but it is a big improvement of standard.
    Headlights - Discussion and Questions-night-breaker-jpg
  9. #129
    Mar 2014
    Perth, WA
    Quote Originally Posted by BFPO40 View Post
    Correct, no street lighting... Will try some other bulbs
  10. #130
    I would suspect a vehicle designed for European speeds has more than adequate headlights. Not sure VW would ever be able to make all the fringe owners satisfied. However, it is possible that the setup for right-hand drive vehicles is not optimized.
