Originally Posted by
JonBoyGTD
Hi. I was wondering if someone could help me please. I have recently (within the last 2 hours) swapped the headlights in my MK7 June 2015 Golf GTD for a pair of brand new Golf Mk7 R headlights. The only difference I can see between my original lights and these new ones is that the Golf R lights have LED indicators and the extra "U shaped" LED DRL. My original lights were the type with xenon low and high beams, 1 x U shaped DRL and cornering lights.
One difference I observed between the two sets is that my original headlights had 12 pins where the wiring loom plug attaches (with pin 4 - when counting from left to right) missing and the Golf R headlights had only 11 pins (also with the same pin 4 missing).
Jon.
Jon: First thanks for the many kind words and what an interesting project!!
I'm not sure that a VCDS cable solution is appropriate for your problem. I've had a look at the wiring diagram for the 11 and 12 pin versions of the Xenon headlight fittings and I suspect that the issues lie with the way the wiring is configured.
The wiring arrangement for the Xenon lamps is spread across a number of pages in VW's wiring diagrams, but I've cut-and-pasted bits of the relevant ciruits to make the diagram below which shows a side-by-side comparison of the 11 and 12 pin configuration:
As you can see, the configuration between the two fittings (from an OEM perspective) are different. I'm not saying that it can't be done, but you might need a cross wiring loom as a remedy. Try the following:- change P13 to P10 - Pin10, socket B on the BCM is the side marker
- change P14 to Pin8 - Pin39, socket B on the BCM (J519) is the main-beam,
- run wire from P4 to fuse #37 (for both left & right side fittings).
For the cornering lights - try removing Pin3 (P4 has been removed as above and now becomes the fuse wire) from the connector (i.e. just leave the CAN high and CAN low lines connected from P1 and P2)
