Results 1 to 7 of 7
Thread: Had GTI on dyno today.
    Mar 2011
    Perth
    Had my Mk 7 GTI on the dyno today. All stock apart from the high flow air filter. Quite high AFR down low for a factory tune.
    Yes it does run lean for quite a while doesn't it. Funnily enough, your power and torque figures are almost identical to my Mk6 GTI thats stage 2. I just had it dyno'd two weeks ago (161kw and 340nm). Mine runs a max boost of 16.4psi.
    Mar 2011
    Perth
    Interesting about the stage 2 similar to my stock Mk7. I just had a stage 2 tune done after this dyno with a 3" dump pipe fitted. I will be getting another dyno run next week to check the power increase etc.
    Not sure what to expect but after driving around this afternoon I would image it should be around 190 kW give or take. It's absolutely insane. It just pushes you back and keeps accelerating with a massive torque curve.
    Jan 2009
    Mulgrave, Vic
    Hi all,
    had mine on a Dyno a week or two ago. APR Stage 1, VW Racing CAI and Milltek 3" non resonated turbo back exhaust, (which I think effectively makes it a Stage 2?) and got this:
    TBH I thought it'd produce more power than 172kw at the wheels, but there you go!
    2016 Mk7 Deep Black Pearl GTI
    Mar 2011
    Perth
    Would you not need to get the APR stage 2 tune to take advantage of the 3" dump pipe?
    Jan 2009
    Mulgrave, Vic
    Hi Dam,
    When I had the exhaust installed the tuner updated the APR software to take advantage of the exhaust. I dont know that this is technically a 'Stage II' as such, I dont thing APR have one released as yet
    Sam
    Mar 2011
    Perth
    Had a Dyno again this morning with my tune loaded. Works out to be pretty much 180KW atw. Was expecting a bit more but happy with the outcome as it really gets up and goes now. So it increased 24.81KW and 58 NM. Feels a lot more but thats what the dyno says lol.
    Had GTI on dyno today.-img_6642-jpg
