Results 1 to 10 of 15
Thread: GTI issues what to do
    May 2012
    Brisbane, Qld
    Hi...so my 2017 GTI PP 80,000K had a warning light and was running very rough for 5 minutes then went away.
    Diagnostics reveal
    - 006704 Leak in Air Intake system
    - 004080 Cylinder 2 misfire detected (P33B0)- During manifold injection
    - several other references to Cylinder 2
    my local garage is wary to help, they cleared the codes and said come back in week, mentioned possible need to clear carbon build up / port clean.
    Should I do that as a matter of urgency or wait to see if the issue retruns.
    thanks James
    My 2015 GTI has both direct injection and port injection = no carbon buildup. Does yours have both?
    Cylinder 2 misfire, hopefully/possibly just a failing coil pack or spark plug. Easy cheap fix if either of those.
    As for the air leak, check all your hose clamps and see if there are any obvious wear/holes in your intake pipes.
    May 2012
    Brisbane, Qld
    My GTI is a 2016 PP so if yours has direct injection and port injection can I assume mine does as well ?
    Quote Originally Posted by jdw View Post
    Not exactly. VW seemed to alternate and some GTI's and R's do have both, and others have just direct injection. No idea why though.
    You would have to physically look at your inlet manifold to see if you have 2x sets of injectors, or just 1x.
    Jun 2018
    Really???? I'd die swearing that all EA888.3 had both injections.
    Second thing I learned this week... The other one was that I always believed that Audi never produced an A4 Avant B8.5 manual until I found one for sale in Carsale.
    Golf Wagon MK7 (90 92TSI) - Mods: DQ250 swap (Stage 2), 110TSI turbo upgrade (Stage 2), Bilstein B12, 19" Pretoria, GTI PP sway bar upgrades (front/rear), full GTI tartan interior, GTI color cluster, R Bi-Xenon headlights with AFS retrofit, GTI brake upgrade.
    More to come...
    May 2018
    Sydney NSW
    Quote Originally Posted by Gutoneto View Post
    Yes that's right and they also brought in, much to my surprise, some manual B8.5 wagons/Avants too (the B8 wagons were all autos in Australia, but there were always B8 manual sedans offered), but the B8.5 facelift look better, has a bit more power, as hte optioon of alcantara seats and I believe the engines used less oil.
    My first choice was to get a near new B8.5 manual Avant instead of the R, but they were too pricey, and they very seldom come up in the used car classifieds, which proves they brought very few in.
    I also assumed all Oz Mk7/7.5 GTI's and Rs were direct injection.
    In America they are direct injection only, so a popular upgrade for people going for big power is to retrofit the port injection setup so they have both direct and port injection. But in Australia, I believe (dont quote me - but I believe) they are a bit of a mix with some being just direct injection and others having both direct and port injection.
    Its easy to check your car, pop the bonnet and pop the engine cover off. Then just to the right of the oil filter you will see a black plastic fuel rail thats just above the inlet manifold runners. Look carefully and you can see an injector just before where the manifold runner joins the head of the engine. These are the port injectors. There are 4 in total of course, one on each runner.
    The direct injectors are underneath the inlet manifold, you can see them and the fuel rail (silver metal fuel rail to withstand the crazy fuel pressure these require) but they are pretty well hidden and you will need a torch.
    May 2012
    Brisbane, Qld
    Issue is Error is for circuit of manifold port injector n533.
    Tested injectors and wiring found incorrect resistance of injector n533- replace and retest.
    Estimate-$836.70-S/f
    Also they say "Visible liquid coolant leak from thermostat housing" I assume this is the water pump issue ?
    Mar 2017
    Tasmania
    Yep, thermostat housing is one of the common leaks. IMO, you don't replace the water pump without replacing the thermostat housing as well. And vise versa.
    Aug 2011
    Mount Colah, New South Wales 2079
    Has anyone any experience of these aftermarket all alloy w-pump/thermostats, currently advertised on Facebook (Sydney)? Priced at $500 or $1000 fitted. Not sure of brand or where they are made - probably China.
    GTI issues what to do-alloy-w-pump-jpgGTI issues what to do-alloy-w-pump-2-jpg
