Page 55 of 56 FirstFirst ... 54553545556 LastLast
Results 541 to 550 of 553
Thread: GTI Edition 40 / Clubsport Thread
  1. #541
    Apr 2016
    Qld
    Quote Originally Posted by Kachingg View Post
    A quick question to you 40y owners how are the 340mm brakes in comparison to the 312mm on the reg gti?
    Is it a big difference or not really noticeable?
    I want to upgrade to the 340mm brakes but the cost is not cheap and if no real difference may just be better to stay stock
    A lot different. Why are you upgrading?
    Volkswagen Mk7 Golf GTI 40Y Clubsport
    Tuned by Tarmac Engineering / Spectune
    @ Bayside Performance Services Cleveland Brisbane
  2. #542
    Apr 2017
    belgrave victoria
    Quote Originally Posted by Mdanrex View Post
    Thb mainly for the looks i have upgraded to 19 inch rims and have been telling myself it's ok the brakes don't look to bad they don't look to small
    Then i see a 3 door performance gti on monday with exactly the same wheels as mine but with the 340mm brakes.....
    I was looking at them and my daughter who was standing next to me just looked at me and said "your going to get them now"
    Sigh i think she is right they just look so much better( i know not the most logical reason to get bigger brakes) and being a big difference is a bonus
    Have found a full set of fronts in usa for 1200 American but dont want the stock discs was looking at dba t3 or t4 rotors will have to speak to a vw specialist
    Thanks for your reply
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
  3. #543
    Apr 2016
    Qld
    Hahaha the only time when size matters but totally understandable mate. Performance wise a lot of difference but I also changed the pads. Looks wise could you look at DBA brand if they had a 340 size for your car? Might be cheaper. You could also ask the Golf R boys as a lot are upgrading to RS or TT brakes and often sell their rotors.
  4. #544
    Aug 2016
    Chippendale, NSW.
    Anyone with a JB1 had any issues with hesitation as to the gear selected. I was coming up to the end of a side road to make a left turn, slowed down and then when I went to accelerate away, it stalled momentarily, which was a bit disconcerting. Luckily no cars were coming, but it could have been dangerous if I was trying to accelerate up to speed, to filter in safely.
    MK7 Golf GTI 40 Years | Carbon Steel | DSG | Front Windows Tinted | JB1 (Map 6) | Sunroof | Folding Mirrors Retrofitted | Current
    W211 E55 AMG | Previous
  5. #545
    Jul 2017
    ACT
    Quote Originally Posted by ringo View Post
    It's an inaccurate indication anyway (the one about power) it's not directly measured as, say, the boost pressure.
    I'm pretty sure the boost isn't directly measure, because you need a manual boost tap for aftermarket gauges to be accurate if you have an ECU tune. This would seem to indicate the boost gauge/display is estimated based on the stock performance of the turbo at gear/RPM/throttle positions, would it not? If this wasn't the case, why would aftermarket boost gauges need a manual tap if there is an ECU tune? It would be interesting to see a stock setup with a boost gauge hooked up the old fashioned way and then compared to the digital readout.
  6. #546
    Apr 2016
    Qld
    Quote Originally Posted by NSNO View Post
    It has done this a few times where there's a flat dead spot and yes a bit scary. Not sure if it's jb4 related or not and it only ever happened in low speed tracking towards a roundabout let's say
  7. #547
    Sep 2016
    I think it is more likely to be a DSG thing than a jb1 or otherwise engine related. The DSG can still very occasionally be glitchy in some low speed environments where rapid changes to "go" are involved. More so in normal mode than sport. Probably because it is exoecting to lazily roll up into second and you have it ripping power down suddenly. Have had this only once or twice in mine.
  8. #548
    Dec 2006
    I get this in full auto and paddle mode.
    Downshifting before turning a corner, just as I want to go around the corner and start applying the accelerator. Hesitating then goes in all modes. When you're sub 30kms it is really noticeable.
    It's not as pronounced in Sport + paddles.
    It's taking some getting used to.
    Sent from my F1f using Tapatalk
    -DIDZ
  9. #549
    Apr 2016
    Qld
    Quote Originally Posted by DIDZ View Post
    Very true
  10. #550
    Jun 2016
    N/A
    Quote Originally Posted by Peekz View Post
    No, car has actual boost sensors that read pressure AFAIK. Aftermarket boost gauges are there only for simplicity, always visible without having to run OBD tools which are anyway slow and limited (i think ECU reports max 1,55bar through OBD - don't ask me why) so it wouldn't be possible to have real-time boost reading otherwise. But the car itself does have dedicated boost sensors.
    Echo the hesitation but also think it's a DSG6 thing not JB1/4 related. In comparison, my dry DSG7 did that only once in 5 years. I have had it 3-4 times in 1 year already with the DSG6.
