Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: GTI 40 edition - RATTLE
    Dec 2016
    AU
    First post.
    Firstly picked up my 40 only last week. Really happy with it, my first VW.
    Only qualm I have is there seems to be a faint-ish rattle coming from the engine bay only when the engine is under load. Particularly between 2-3.5K RPM.
    It almost sounds like someone is dragging a chain on a tin surface, except they are half a K down the road haha. Weird I know. I can't replicate the sound when the car is not moving.
    Anyone else experienced this? If so what is the fix? This is a MY16 40th built in June.
    I am taking it back to VW on Friday anyway. Only 250ks done.
    Can't fault the car in any other way - but for 50K you would expect better.
    Comments appreciated.
    Sent from my SM-G935F using Tapatalk
    Jan 2013
    Brisbane, QLD.
    Wastegate rattle most likely.
    Apr 2011
    Geez, you'd thunk they would have gotten the hang of this after 4 years!
    Jun 2016
    N/A
    Does it sound like this by any chance?
    https://www.youtube.com/watch?v=gXR40RQYEb4
    or this:
    https://youtu.be/1vFovml9C7A
    Like a vibration becoming apparent around 2.5k and then disappearing? if it is that, that's the fuel lines not the waste-gate.
    Nov 2009
    It certainly sounds like you're describing the wastegate rattle that affects almost all cars with this engine/turbo combo (Golf R, Audi S3, etc etc).
    Golf R Metallic Ringing Noise
    Anyone know if there is a TPI/TSB for this for the mk7 ? I have not heard of it to date. Bugger ... check these out:
    * Fuel lines
    * Wastegate rattle (was an mk6 issue .. not again!)
    * Soundaktor (more of a buzzing sound, maybe not related)
    rattling noise under the dash acceleration. - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    VWVortex.com - Question about soundaktor
    There was a lot of mucking around with the clips on the Mk6 with dealers feigning ignorance etc.
    Hope you get it sorted out.
    RS
    R
    Central VIC
    Quote Originally Posted by AdamD View Post
    Ah yes the dreaded wastegate rattle- you'll find your ever helpful local VW service department will fob you off with "its a charactertistic of the engine"....seems like they are spending too much fixing Dieselgate to fix this issue.
    Dec 2016
    AU
    Thanks for the replies guys. I will not accept VW telling me this sound is normal. Will keep you all posted.
    I read elsewhere the downpipe could also be the culprit? Does anyone else own a 7 gti or r with this issue?
    Dec 2016
    AU
    Quote Originally Posted by ringo View Post
    or this:
    Doesn't sound like this! More like a ringing sound.
    Central VIC
    ^ The way you describe it GTI40 sounds exactly like the Wastegate rattle many R's (but not all!) have: as the GTI40 effectively shares the R's motor, one would expect similar proportions of GTI40's to have the rattle. There are a couple of guys here who have replaced their DP with good effect however this also requires a software tune (Stage 2) and loss of drivetrain warranty (not too mention $3-3.5k of further expenditure). I have however read on UK forums of a few people who havent had success with the DP replacement removing the rattle. I wasn't prepared to do this with my Wolfsburg R, and was absolutely stonewalled by VWA so ended up selling it as the sound ruined the experience for me.
