Page 24 of 30 FirstFirst ... 142223242526 ... LastLast
Results 231 to 240 of 295
Thread: Group Buy: Aftermarket Bixenon Headlights (WinPower Lamps)
  1. #231
    Nov 2013
    AUS
    Well I've just finished going for a night drive. The left headlight is absolutely useless, illuminates only 5 metres ahead of the vehicle. The right headlight at the maximum height is not high enough. Around town the right headlight beam is passable only because there are plenty of street lights around but when there aren't (as you'll see in the 2nd video), the light beam is inadequate in distance and power.
    I took the following videos on my GoPro Hero 2:
    Driving around town WPlamps Golf 7 - YouTube
    WPlamps Golf 7 driving in the hills - YouTube (or the short version: Driving in the hills WPlamps Golf 7 V2 short version - YouTube)
    Comparison photos of OEM headlights with Osram Nightbreaker Unlimited vs WPlamps V2 headlights:
    Osram NBU
    WPlamps (the cutoff isn't as crisp as the OEM halogen lights which is disappointing, also doesn't stay nice and horizontal off to the sides)
    Osram NBU
    WPlamp
    Osram NBU
    WPlamp (notice how the left side is not as well lit, also the right side trees and road guards are not lit as well as the stock halogen headlights)
    WPlamp low beam (notice the left beam cutoff seen as a hotspot)
    WPlamp high beam
  2. #232
    Jul 2014
    I installed mine today, when I first installed them the right headlight was way too low but after lots of adjustment I think they're all good now. Sorry to hear about you guys having problems
  3. #233
    Nov 2013
    AUS
    Well I contacted Mark Sunday night about my issues, he said that the reason why the left headlight was limited in upward adjustment was because the left/right adjustments were at their maximal. Well, after much adjustment with the left headlights (both with the lights on and off the car) there was almost no difference in beam height. The right headlights adjusted much better. With the internal headlight beam adjuster set to the highest, it was able to go higher than I needed when adjusted to its highest setting using the rear headlight adjuster (useful for driving on dark, empty country roads with infrequent oncoming traffic without necessitating the use of high beams).
    A drive around town demonstrated an improvement compared to before. As the source of illumination was solely from the right headlight (the left headlight just pointed to the ground or at the left rear tyres of cars in front) there wasn't the power you would expect of xenons. If only the left headlight was able to be aimed up at the same level there would be additive lighting power where the beams crossed over.
    https://www.youtube.com/watch?v=R6CKZBtw2oM&feature=youtu.be
    Before maximal adjustment (low beam)
    After maximal adjustment (low beam)
    Before maximal adjustment (high beam)
    After maximal adjustment (high beam)
    Driving in the hills again demonstrated an improvement but was disappointing in illuminating the left roadside (useful to see wildlife or mobile speed cameras around town?). As the WPlamps xenon beam cutoffs taper downwards the further away from the beam, it doesn't illuminate corners as well as my motorbike used to (which had $120 projector bixenon headlights) just before entering corners.
    https://www.youtube.com/watch?v=FgGJ..._n_46H15LIsUUw
    My motorbike bixenon beam
    I've had a good look inside the low beam housing to make sure that turning the adjustors was actually doing something. The yellow plastic part in the bottom left adjusts the headlight height.
    https://www.youtube.com/watch?v=IMfy..._n_46H15LIsUUw
    The adjuster set at the lowest beam height
    The adjuster set at the highest beam height
    An interior inspection video of the low beam housing: https://www.youtube.com/watch?v=oVCt..._n_46H15LIsUUw
    As the adjustors chew up easily, as seen by the left/right adjustor on the left headlight, I could only adjust them with the headlights off the car.
    They should look like this:
    Overall I'm just frustrated with the whole process with these headlights. They're not up to scratch, shouldn't have passed their QC as they are and as a result I've wasted a sh*tload of time on these headlights. I'll see what Mark will offer but I'm not sure what I'm going to do just yet.
  4. #234
    Nov 2013
    AUS
    I spent all yesterday afternoon and night trying to reset the headlights multiple times. I tried to reinsert the adjustor fully extended and fully shortened and tested to see what the headlight level was like and how much it could be adjusted. Unfortunately it wasn't able to be adjusted any different despite having the right/left adjuster in the middle of its range.
    This is the video Mark sent me to reset the adjuster: Golf 7 Wplamps V2 - resetting the headlight adjuster - YouTube
    I saw Leovasquez have the opposite problem to me where one beam was too high.
    Entrar - forum.VWGolfClub.com
    His problem was the headlight adjustor was not clicked into the white piece as shown in the photos. After he clicked it in it was in the right adjustment range. The problem with my headlights was there was not enough range with the adjustor to push the bottom of the headlight to aim the beam high enough. I ended up leaving the yellow adjustor not clicked into the white plastic, I tied shoe lace string (I tried sewing thread but that broke) around the white part and the yellow adjustor ball so they stay together when I adjust the yellow adjuster up and down. This has resulted in the left beam higher than before and is within acceptable normal limits.
    This is a short video showing part of how I went about doing the ghetto modification, it wasn't easy but was made slightly easier with decent gloves and mosquito tweezers and needle tip clamps. The video starts after I had already made my initial loop around the white plastic part.
    http://youtu.be/J8vcBQbfaCc
    Video driving around town after the ghetto mod:
    http://youtu.be/qRd0bJU2ZPs
    Video driving in the hills after the ghetto mod:
    http://youtu.be/Du8Eh5f_N28
    Despite finally reaching a satisfactory light beam output and height, I'm very unhappy with how these headlights were sent. Without the modification the left headlights would still be pointing down at the road only 4 metres in front of the car.
    This is a fault with the headlights and it should have been picked up in QC.
    I spent considerable time researching and making sure I would end up with a good product that didn't require me to spend days fixing and installing the headlights! The problem with this whole group buy was Mark rushed us into completing the group buy, with a reduced minimum number of units before August, promising they would be made before their busy production period in August. Mark failed to check with production that they had enough material to fulfil the promise of producing the headlights and shipping them out 4 days after payment. There were multiple delays, the rush in production causing quality control issues resulting in further delays, these headlights came so late in the Paypal Buyer Protection period. Today is the last day for me to open a Paypal dispute which is why I had to make sure these headlights reached a level I could use. The option of returning the headlights would come at a considerable cost to me and therefore is a last resort.
    I'm currently seeing if Mark will compensate me for the substandard headlights, the amount of time I've put into the group buy and the business I've brought him. We'll see what he says, for me this was a lesson learnt. No amount of preparation with Chinese manufacturers such as WPlamps will minimise the amount of sh*t that will hit the fan.
    Edit: I opened up a Paypal dispute, will see how this goes.
  5. #235
    Jul 2014
    OK...so after seeing a few people with issues, I decided to check out my own headlights. I managed to get the grill off, but then I got stuck with trying to remove the second screw holding the bumper in place (the one closer to the front) - I just couldn't find it.
    And it could be just me but the plastic cover shown in Page 3 doesn't look like mine. Mine looks like 2 pieces and the bottom part seems very firmly fixed. Anyway, I didn't investigate too much further because it started raining so I quickly put everything back together =(
    However, I would like to test that at least the lights work, does anyone have any pics or instructions on what connectors I need to use to test the lights?
    And given the crappy weather in Sydney right now, I am very tempted to pay someone to install and code them at this stage.
  6. #236
    Jul 2014
    Yeah mate, all the cables from the light plug into the ballast cables and then the cable from the car headlight plugs into the back of the ballast. Just sit your new headlights on top of the old ones, they're pretty easy to test out
  7. #237
    Jul 2014
    I know this might seem dumb but if I plug in all the cables from the headlight into the ballast, there are no cables left. I've only got 3 cables and the headlight has 3 cables. Did I get a dodgy ballast?
    Group Buy: Aftermarket Bixenon Headlights (WinPower Lamps)-dscf3050-jpg
    And which cable should I pull from the existing headlight?
    Group Buy: Aftermarket Bixenon Headlights (WinPower Lamps)-dscf3051-jpg
  8. #238
    Pull this plug:
    Insert it to here:
    PS. - Sorry Andrew I took your pic :-p
  9. #239
    Jul 2014
    DeusLucem, see the front page of this thread, theres a picture with red circles on how to connect the ballast to the headlight.
    Pull the cable with red circle out, and put it into to your new headlight. Theres a slot that you can see if you look carefully on the inside of the WPlamp headlight
    edit: michael beat me to it. lol
    '16 Polo 6C GTi | Flash Red | H&R Touring Cup Kit 35/55 | Milltek Cat-Back NR | Phillips/Konik 5000K
  10. #240
    Nov 2013
    AUS
    Hey Deus, after my first attempt to do the install, I came across this video, it is an awesome walkthrough of how to do the headlights! Shows you how much force the car will actually take (a lot more than you expect)
    https://www.youtube.com/watch?v=ymfSdOdjprQ
    Current:
    2017 Mk2 Tiguan 162TSI, R-line, White
    2020 Mk7.5 Golf R Wagon, White
