pics! please
'16 Polo 6C GTi | Flash Red | H&R Touring Cup Kit 35/55 | Milltek Cat-Back NR | Phillips/Konik 5000K
Sweet!!! Will contact him in the coming days. Thanks for the quick reply.
Just an update on my install – GTI
Mechanically the new units went in, after some time…….
I have not done any coding (if I can get the things to work, I might consider it)
When the car light switch is in low-beam (HID) only mode;
Both HID lamps on both sides are lit.
The passenger side front DRL is partially lit (this is NOT reflected light from any source), see attached *.jpg file.
After a few minutes the passenger side HID flickers and goes out. The driver’s side HID remains lit. At the same time, all DRL’s become lit (driver’s and passenger’s sides). The HID on the passenger’s side will not turn on, see attached *.jpg files.
I’m talking to Mark at Winpower, trying to work out what’s wrong.
Mark believes it is a coding issue. I don't think so.
I’ve commenced a Paypal dispute, my only protection. :
Some other pics, ...won't load!
Winpower have advised that they want me to do the coding (that I haven't done WTF?) before they will consider a ballast/controller solution.
Does anybody have a VCD who can help me in the Parramatta area asap ? Please PM me.
Thanks.
Last edited by KWS; 28-08-2014 at 02:47 PM. Reason: Further information from Winpower
KWS, the problem sounds similar to mine that I had earlier. See if you can get to the back of your headlights and open up where the ballast leads go in, and check the connectors in there, one of them might be disconnected (pics in my post #169)
Yeah, I've already pulled the thing out totally, disconnected every wire/connector and reconnected. Even took the HID bulb out to check the wiring on the end of it. Still the same problem.
I'm hoping somebody with a cable can help, even if it's only to prove the coding is not the issue.
How can coding be a problem if it's never been touched, or am I lucky enough to have my own special code assigned by VWA.
I don't think so!
Well this is retarded. I tried to do the installation of the headlights but got stuck after removing the M10 bolts from underneath the bumper. The bumper wouldn't swing out like it would in the photos and after a fair amount of fiddling, cussing and praying I don't break the bumper, I gave up and rescrewed everything back on.
I temporarily connected my headlights up last night and they seem to be operating satisfactorily so I'm happy with that. I just need to find someone willing to fit these headlights for a decent price.
