Have you try this site instead? DHL | 按发件人参考信息跟踪 | 简体*文
Type your number on the top right hand corner should come up with the package log.
I think I'm doing something wrong... The website says the tracking number needs to be 13 digits but mine is only 10
Mine is in Brisbane custom atm, if I'm lucky the lights could be my weekend project hahahaha
Mine are in Sydney, too! Haha. Probably will arrive tomorrow!
Shame I don't have a car to put them on -_- lol.
Looks like the dhl people should be getting ours today!! Mine's "with delivery courier"...so keen!
Edit: just got mine. won't be fully installing them until tomorrow, but I'll post some pics up of my external test.
'16 Polo 6C GTi | Flash Red | H&R Touring Cup Kit 35/55 | Milltek Cat-Back NR | Phillips/Konik 5000K
Based in Sydney. Just got mine delivered. Won't be able to test them until Sunday at the earliest. But will try to put up some pics of unboxing tonight.
Alright so I've just taken a few pics of the lights sitting on top of the stock ones. I haven't removed them yet. First two pics are the led DRLs only (left and right) and the last two pics are the xenon projector main beams on. Are the leds meant to be turned off when the main beams are on? I'm not sure...
EDIT: I emailed Mark about it. Apparently you need to do VCDS coding as below:
Using the VCDS 12.12.0 program:
1 - Go to the module [09] CENT. ELETRONICS
2- Go to "SECURITY ACESS"
3- Digit the code 31347
4- After the code is acepted, go to ADAPTATION
5- Select Channel (5) Leuchte4TFLLB4 - Lichtfunktion B 4
6- Change status to "Abblendlicht Link"
5- Select Channel (5) Leuchte5TFLRB32 - Lichtfunktion B 5
6- Change status to "Abblendlicht Rechts"*
Out of curiosity, does anyone in Brisbane have a VCDS cable?
Mate looks awesome! So excited to get mine!
VCDS will be required to enable the DRLs to remain on (at varying levels of brightness) while the low beam headlights are on.
DRL tweak via VCDS (in Portuguese but VCDS screens in English)
https://www.youtube.com/watch?v=Q5Gvy8RG3ik
Is the VCDS re-programming required for all models? I noticed my GTI has what appears to be non-LED DRLs so I'm thinking that the swap should be like for like.
