Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Golf W MK7 2015 Head Unit upgrade for revers camera
    Quote Originally Posted by Ismurdegus View Post
    Hi Don
    Thanks for your replay, I must explain myself not clear....like I usually do
    Lets' start from the beginning again:
    I have a Golf MK7 2015 without reversing camera. The MIB unit installed is an: 5G0035819A
    I also have a Caddy 2016 with reversing camera. The MIB unit installed is an: 1K8035150A
    I have the VCDS cable and software installed on my laptop and working 100%.
    I find on marketplace an used MIB de-installed from a Transporter 2017 with model number: 1k8035150H
    The seller said that the vehicle didn't have reversing camera installed.
    There has been no confusion regarding these facts - I have understood your words 101%!!
    My question is: the unit for sale on marketplace has the identical (apart for the last letter) model number of my Caddy that has reversing camera, if I install this unit on my Golf and use the VCDS software for do an "Adaptation channel map" I will still have CP errors....correct?
    YES!!
    If the answer is YES, I am screw because I can only install the reversing camera at a dealer.....that will charge me possible $5K
    Correct - you are right-royally screwed (meaning f#*ked-up on a large scale)!
    But don't take it personally because you are in very good company - anyone who tries installing a MIB (that hasn't been hacked) into a car that has a different VIN to the original factory fitted car is also screwed!!
    Not sure about "$5K". If a dealer is prepared to clear CP errors on a MIB that the dealer hasn't installed - i wouldn't be surprised if the cost is somewhere close to the annual budget of a small African nation!! Which is obscene and outright theft because the actual ODIS procedure for clearing CP errors is not complex
    Nov 2007
    Contact Kamold on this forum. He may be able to help you.
