Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 145
Thread: Golf R Metallic Ringing Noise
  1. #21
    Central VIC
    Indeed.
    And a spouse-friendly reason for why one must go to stage 2.. "just clearing that ringing sound".
    lol good point dutch
  2. #22
    Feb 2010
    Ok yeah, it's definitely gone. We have a solution - Stage 2!
    I've got the stock DP in the garage, I'll take a look tomorrow and see if I can pinpoint the bit that's vibrating. Maybe if you can attach a lead weight to the heat shield using some heatproof silicone adhesive, it may stop it resonating. I'll post up some photos when I find out what's vibrating.
  3. #23
    Central VIC
    Sensational news Primordial! Appreciate your work
    (btw, I noticed this morning on drive to work I had less ringing/rattle in "Normal" mode....).
    So, stage 2 is looking good! (I have a recommended VW independent specialist in Melbourne who supply/fit CTS downpipes with Revo tunes so that's probably the way I'll go I think. Wondering does the CTS DP come with is own heat shield?).
  4. #24
    Nov 2015
    Darlinghurst, NSW
    Seems like good news! I wonder if this can be transferred into a fix through the dealer
    Andrew7 I thought the noise was less in Eco mode and that it was something to do with the sound actuator not sending as much sound through into the cabin, but it wasn't really that distinguishable from Normal and Race modes
  5. #25
    Jul 2009
    QLD
    Primordial appreciate the feedback, I've got an R on order due around Christmas was starting to have second thoughts after reading this thread. Sounds like a component change may have caused this issue no doubt many sources of parts for cars today. Can't see myself going Stage 2 day one so hopefully a fix to the heat shield drillings or balast may fix. Looking forward to all the other mechanical sounds the R makes though.
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
  6. #26
    Central VIC
    Quote Originally Posted by TFAD View Post
    ^ Re the soundakator, there have been previous issues with it rattling, but the noise you describe is identical to mine which is clearly in the engine bay somewhere (or above the OEM DP). Increasing the level of the soundakator to my mind just hides or makes it slightly harder to hear the ringing noise (though it is still there), shouldn't on the face of it alter the ringing noise (I hear it loud and clear when in Eco mode).
    I may as a starting point investigate ?replacing/upgrading the DP heat shield and see if that's the solution. Suppose an exhaust/muffler mob could help with this (?). (it does seem slightly extreme to need to go to stage 2 to sort out a factory problem )
  7. #27
    Feb 2010
    Quote Originally Posted by andrew7 View Post
    The CTS downpipe does not have a heat shield. None of them do except for one to my knowledge (which I can't remember the brand), but that one was stupidly expensive.
    I wrapped mine with titanium wrap: DEI TITANIUM EXHAUST WRAP 2''X50' | Heat Management | Revolution Racegear
    It's pretty easy to do actually, and the under-bonnet temps are now lower than the stock downpipe. It seems the heatshield on the stock one was to block heat from sensitive components, rather than keeping under-bonnet temps down. Titanium wrap keeps the outside of the pipe cool (keeps the heat IN), all the way down out of the engine bay. Also the higher temperature inside the downpipe speeds up the exhaust flow. You want gasses on the hot side of your turbo as hot as possible - higher heat means lower density. How much of an effect this has I don't know, but for a little extra, the wrap made sense to me
    I was kind of kidding when I was suggesting that stage 2 is THE solution. It is one solution, but not the be-all/end-all. You're right, an exhaust mob may be able to help. I'll try to pinpoint the part of the heat shield that's vibrating tonight and post some pics. It may be a simple fix, not requiring professional help.
  8. #28
    Central VIC
    You're a legend Primordial, very much appreciated
  9. #29
    Feb 2010
    Ok guys, well I have good news and bad news.
    I'm pretty sure I've found the source of the rattle. The bad news - I don't think it's going to be easy to fix, without removing the dump pipe to fix, or by replacing it obviously..
    The rattling sound sounds suspiciously like the metal shroud/cage around the downpipe flex joint. Unfortunately this will be pretty difficult to access without removing the downpipe. Likely why VW wont release a 'fix' for it, because its at least 3-4 hours of work just to get the downpipe out!
    I made a quick video to explain:
    All good bud, happy to help
  10. #30
    Central VIC
    Thanks Jon, great detective work. It's looking more and more like a new DP is the way to go 😄 (and therefore an intake and tune as well 😜 )
