Golf R Metallic Ringing Noise
Don't know if it's related, but my MY15 103TSI has a metallic noise (sounds like someone playing a cymbal really fast) that's most audible whenever the wastegate is open. Ie. On boost, backing off and downshifting. The symptoms are consistent with the original post, with exception to the rpm range.
The dealer mechanics said this is not the same issue as MY13 models that needed a clip fitted as newer model actuator arms are welded to stop rattle.
The result is they have ordered a new actuator arm to see if it fixes the issue. Failing that, replace wastegate...
Noise comes in from driver side footwell, and resonates in the car if windows are up around 3-4K rev.
Golf MK7 103TSI Highline Wagon | Limestone Grey | DAP2
Golf MK7 110TDI Highline Hatchback | Tungsten Silver | DAP
