Have this exact thing on my gti too. Definitely not wastegate or sound actuator. Much lighter rattling. Also told it was a characteristic of the engine
I got this in my R wagon also from the day I picked it up.... Always thought it sounded like a exhaust heat shield or something vibrating at lower revs when under load.... It's bloody annoying! They did such a good job of muffling the actual engine sound that they needed to make a soundaktor but they can't hide this noise haha!
There are definitely two distinct issues at play - I had the wastegate issue on my Mk6 and that was definitely different to the issue here which 'featured' on my Mk7 instead.
Interesting that it's not consistent across the board again per Andrew's tale; I'll be interested to see if an independent can resolve it and what the fix is.
Wondering if a replacement aftermarket DV valve might do the trick?? I am on a mission to eliminate this noise!
I can hear this sound in my Golf Alltrack too, in about the same rev range (between 2000 and 2500rpm). I wasn't sure what it was, but I'd expect it's the same thing as mentioned above. Pretty sure the 1.8 litre TSI is from the same EA888 engine group as the 2.0 litre GTI and R variants.
Agreed, it does take a little shine off an otherwise brilliant engine package.
2019 Tiguan 132TSI R-Line Edition MY19.5 - Tungsten Silver - 2.0 litre TSI 132kW + Panoramic glass sunroof
damn......
next theory: there was someone on the VW Vortex forum who installed a new ABT downpipe which somehow eliminated the ringing noise. He theorises that the existing OEM heat shield above the OEM downpipe amplifies the sound (the ABT DP comes with a titanium thermal wrap)....
On man.. actually.. I had a CTS downpipe fitted on the weekend. You know what, I think the sound might actually be gone on mine too now that I think of it! I usually cringe whenever I hear it in the morning after cold start, but I don't think I've cringed all week!
Shall test later today and let you know.
Indeed.
And a spouse-friendly reason for why one must go to stage 2.. "just clearing that ringing sound".
