For anyone following along, worked out with my mechanic (not VW) that the wastegate indeed has failed and is causing me to loose boost. New turbo is on the way..
If you refer to my link posted previously, you can buy a replacement wastegate for just under $700 vs multiple thousands for a new turbo. Unless you have warranty covering this repair then it would be wise to only replace the failed item.
