Page 13 of 17 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 164
Thread: Golf Mk7 Towing/Towbar Thread
  1. #121
    Mar 2017
    Tasmania
    If I had my time again, I would have installed a westfalia on my Passat Alltrack Wolfsburg rather than the VW Aus towbar. The westfalia are are much neater installation IMO.
    Jun 2012
    Maroochydore, QLD
    Golf Mk7 Towing/Towbar Thread-golf-7-towy-jpg
    Golf Mk7 Towing/Towbar Thread-golf-7-towbar-jpg
  3. #123
    Blackburn South, Victoria
    Quote Originally Posted by Euro Car Upgrades View Post
    wonder what the tow ball weight limit is on those types.The VW & HR ones for my passat alltrack state 90kg tow ball weight limit.
    2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
    2023 MY23 Nevada White Cupra Formentor VZx
    2015 Carnival Yellow Honda S660
  4. #124
    May 2011
    Albury / Wodonga
    The tow ball weight should still be 90 kg. It’s set by the car, not the ball if you get my meaning. We had a 300+ kg capable HR ball on the Passat but it was limited to 90 kg because that’s what VW said it should be. I suppose it’s theoretically possible to put a ball rated less than 90 kg on the car but it would need to be made out of pipe cleaners or attached to the number plate fittings.
    Looking for:- RS4 B7 Avant.
    Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
    Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
  5. #125
    Pacific Paradise QLD
    Yep the ADR rules on towing are
    The rated towing limit of the towbar or the vehicle as set by the manufacturer
    Whichever is the LESSER
    EG
    Towbar 2500kg Car 2000kg =2000kg
    Towbar 1500kg car 2000kg =1500kg
    The towball limit is whats in your cars manual and is the limit set by the manufacturer
    So if the towbars ball limit is 150kg and cars limit is 90kg =90kg No way around it.
  6. #126
    EG
    Yep, i understand the rules. Just those ones look "flimsier" than the square removable VW or HR ones that are on my passat. So i wondered if they had a lower weight limit.
  7. #127
    Quote Originally Posted by FarQ View Post
    Fair enough but wasnt aimed at you or anyone Is just a general heads up as lots dont know or dont understand
    The Westfalia ones will do the job they are rated for HR are embedded in heavy towbars for towing vans and havent worked out that a light one will do for small cars
  8. #128
    Jun 2012
    Maroochydore, QLD
    Westfalia gooseneck attachments on its own are rated at 6 Tonnes on its own.
    Its the car which limits you.
    There is also a difference in calculations between ADR and other design rules.
    Quality of HR tow bars which are made in Thailand and China nowadays is questionable from the install perspective.
    Last one ATP did on HSV Commo - instructions says drill 13mm holes - nowhere near fits. The rep said - just drill 24mm - she'll be allright.
  9. #129
    Oct 2009
    Mitchelton, Qld
    Anyone know if you can fit a towbar to a Mk 7.5 Golf R wagon?
  10. #130
    Jun 2012
    Maroochydore, QLD
    Quote Originally Posted by donweather View Post
    Yes you can, different bar to hatch and wiring need to be done to your dash as no preparation on these.
