If you have a wagon contact HR for a release date.
I've only towed once with my HR and it's fine so far. I don't have the VW loom so the sensors don't get turned off. There are no warnings.
I may consider getting the loom at a later time.
Greg
MY14 Golf Wagon Highline 1.4L TSI 103, Limestone Grey Metallic, Roof, Leather, DAC.
Greg
Thanks Greg. What's the impact of the sensors not being turned off? Is it just that they detect the trailer when you're in reverse?
Yes that's it. The better you are at reversing the less of an issue. Its a big issue for me
Greg
have pulled the trigger on a full HR setup. Installer would put in the VW wiring if I wanted, but my VW dealer knows so little about it they were thinking it might cost ~$600 to install - over 3 hrs. HR installer allows 30 mins for the HR wiring. Would have liked to have the real deal, but not at that price.
Hayman Reese towbar fitted. Involved a rear bumper cut (in the grey area at the bottom). Looks a good job, so now I just need to find a hobie cat to tow
What do you think of this? genuine Tow Bar for Golf 7
An option which is available in Australia now with genuine VW module so the tow bar works with the car:
It's in the region of 1500 fitted. HR is significantly cheaper but that's without the VW loom. Do you need the VW loom.
Check out the towbar thread for more.
Greg
I had a Westfalia tow bar fitted in Adelaide last week and was told unofficially that the German made wiring loom is the same as the VW item but with a different name on it. Cost was a little under $1,400 and the ECU programmed as required. I need to find out if the reverse beepers should be disabled when a trailer is hooked up (mine still beep), otherwise it works as intended.
