Page 15 of 17 FirstFirst ... 51314151617 LastLast
Results 141 to 150 of 164
Thread: Golf Mk7 Towing/Towbar Thread
  1. #141
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by GolfRWag View Post
    Yes, as I understand it VW did not homologate/assess/rate the R for tow capacity.
    Im sure the car is quite capable of towing a moderate load eg: sub 1000kg. Chassis- wise it’s the same as the Golf Alltrack, though the tyres load limit maybe a potential issue if the car is also loaded, and the springs/ride height may not have sufficient travel for potential loads.
    Which is not to say you cannot fit one, for say a bike rack. There’s some UK Golf R sedans and wagons running about with tow bars for just that purpose.
    I'm wanting to tow a jetski.
  2. #142
    Canberra
    [QUOTE=donweather;1309206 I'm wanting to tow a jetski.[/QUOTE]
    Simply put - can't be done legally unless you get an engineer's certificate valid for your state.
  3. #143
    Mar 2017
    Tasmania
    Quote Originally Posted by gregozedobe View Post
    for towing, an engineers certificate can not override the manufacturers zero towing allowance.
    Canberra
    Quote Originally Posted by doc_777 View Post
    That's interesting, sounds like you will be unable to get a valid certificate.
    I thought it would be similar to GVM, some years ago I had a Landcruiser ute that I put a camper body on and had to upgrade the suspension for the extra load and get an engineer's certificate for the increased GVM (in the ACT).
  5. #145
    Pacific Paradise QLD
    Yes because that was allowed as it had a GVM rating which under certain conditions it could be increased legally.
    The GOLF has a zero limit and therefore cant be.
  6. #146
    Nov 2018
    Blackburn Vic.
    Some UK types have done towbars on hatches and wagon R’s, here’s one: Estate Towbar - VW Golf R MK7 Chat - VWROC - VW R Owners Club
    and on a hatch:Towbar on a mk7 R - VW Golf R MK7 Chat - VWROC - VW R Owners Club
    There is some cutting of the rear valence required.
  7. #147
    Nov 2018
    Blackburn Vic.
  8. #148
    Unfortunately what they may be able to do in other countries is apparently not legal to do here
  9. #149
    Nov 2018
    Blackburn Vic.
    It’s perfectly legal to add a towbar as long as you don’t tow with it. Bike racks is what they have done it for in the UK.
    I was giving this some thought before I got my car so I could add a bike rack, but I can stick 3 on the roof so that was enough for most occasions when I needed to.
    Personally I would remove the towbar prior to disposal if I did.
  10. #150
    Oct 2009
    Mitchelton, Qld
    What I don’t understand is why can you get a towbar legally and VW approved on a normal golf but not on a golf R? They’re essentially the same car (body/structurally) apart from suspension and engine upgrades.
