If I had my time again, I would have installed a westfalia on my Passat Alltrack Wolfsburg rather than the VW Aus towbar. The westfalia are are much neater installation IMO.
2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
2023 MY23 Nevada White Cupra Formentor VZx
2015 Carnival Yellow Honda S660
The tow ball weight should still be 90 kg. It’s set by the car, not the ball if you get my meaning. We had a 300+ kg capable HR ball on the Passat but it was limited to 90 kg because that’s what VW said it should be. I suppose it’s theoretically possible to put a ball rated less than 90 kg on the car but it would need to be made out of pipe cleaners or attached to the number plate fittings.
Looking for:- RS4 B7 Avant.
Current:- Amarok V6 Sportline; Mazda CX-9 Azami AWD
Previous - Mk 6 R manual; Mk 7 R manual; Passat 130 TDi Wagon. Mk 7.5 Wolfsburg Wagon.
Yep the ADR rules on towing are
The rated towing limit of the towbar or the vehicle as set by the manufacturer
Whichever is the LESSER
EG
Towbar 2500kg Car 2000kg =2000kg
Towbar 1500kg car 2000kg =1500kg
The towball limit is whats in your cars manual and is the limit set by the manufacturer
So if the towbars ball limit is 150kg and cars limit is 90kg =90kg No way around it.
Westfalia gooseneck attachments on its own are rated at 6 Tonnes on its own.
Its the car which limits you.
There is also a difference in calculations between ADR and other design rules.
Quality of HR tow bars which are made in Thailand and China nowadays is questionable from the install perspective.
Last one ATP did on HSV Commo - instructions says drill 13mm holes - nowhere near fits. The rep said - just drill 24mm - she'll be allright.
Anyone know if you can fit a towbar to a Mk 7.5 Golf R wagon?
