What happens if you download the map straight onto the card.
Did you format the card before you downloaded the map
Hi Guys,
I tried to update my Golf Mk7 2013 navigation maps with the DiscoverCare_v.1.0.4_win tool and things went bad, the content of the SD card was not backed up and now basically i dont have maps anymore.
I have checked and the files were not backed up on the computer.
I spent hours reading on forums and it seems that if you just copy back the back up content should work.
If anyone here reads and has a V1 card and can upload or transfer somehow the contents of their SD card please help.
I have the original SD card 5G0 919 866A Multi region Map but dont have the original content as it was deleted in the process.
Kind regards.
I have tried and will not work.
If doing it from the DiscoverCare_v.1.0.4_win will download only a update that is 404mb and downloading the Zip from Volkswagen Map & Softwareupdates and copying it to the SD Card will only give me this message :
Looks like it s the wrong map DID YOU FORMAT THE CARD
You can't affect the hidden partition with the license information using a format.
The license in the card is good for 3 years of maps updates.
After that you need to install either the last previous maps to which you had a valid license, or get a new sdcard which will then get you another 3 years of updates.
The cards are available from vw spares for something like $240 or so (don't quote me).
Thank you for the answer, sucks in all way possible my situation.
Do you think that a different version of SD would work ( mine is V1 ) or i should say goodbye to the nav system?
Back to the start i guess, if anyone has a V1 card and can share the contents from it would be highly appreciated.
