Originally Posted by
wookie_666
Hey Dv52, ive had a request from a few people in the US to see if we can do the same with the ESC button,
Basically pressing it for like 4 seconds after start.
Ive had a look, the button is low when in neutral state, and HIGH when pressed.
the weird thing is, when testing continuity with a multimeter, this also acts as pressing the button,
Its between VCC and PURPLE, or the wire right next to VCC
I Was wondering if you had the wiring diagram or knew where to get it to see if this is possible at all.
Cheers.
wookie: Interesting problem - from the wiring diagram, the ESC/ESP Switch mercifully looks to be the same as the SS switch in that it is a single-throw, single pole switch. But the circuit wiring for ESC/ESP Switch is the electrical reverse of the SS Switch: as you say - it connects +12 Volts to pin #39 on the ABS module (this shouldn't be a problem).
My only concern is whether the ESC switch is the latching type: does the disable/enable function work on the leading/trailing edge of the +12 Volt source like the SS Switch, or does it need the +12 Volt to remain applied?
When the ESC switch is pressed and then released, does the switch return to the normal position, or does it latch in the pressed state (and then return when pressed again)?
Assuming the answer to my question above is NO - here's how to modify my switch to operate as an Auto ESC Kill Switch:
PS: My guess when you used the multi-meter to test continuity is that the ABS module saw the internal battery in the multi-meter as a surrogate for the +12 Volt supply from SC34 in my picture. As you probably already know, continuity testing involves measuring the electrical current from a known battery voltage internal to the multi-meter
